Some stupid cooling ideas... Discouragement needed
Right, I like to tinker and I especially like to overdo things.
So, I've been thinking about cooling my PC in some of the most stupid ways possible lately...
The latest idea in the long line is to find a car radiator fan and hook it up somehow, if it's possible(research required) to the PSU. The general idea would be to have just one giant fan, probably as an intake, thinking if it'll start and run at 5 volts at a liveable noise level it'd be kinda worth it.If the draw is too great for the PSU, considering it'd be running at less than 50% rated voltage, I do have some 12V poweradaptors, but I'd need something to change the voltage preferrably with a voltage display etc, I don't currently have one, but I do have an idea on how to build one from some other junk I have.
The reason I thought about that is that I want to modify an old refrigerator compressor I have sitting around to run coolant loops behind the mobo tray, underneath the gpu and around the closed loop cpu water cooler radiator. The reason I want massive airflow through the case is to avoid the obvious issue of condensation. Although I don't really think it'd be enough. I'd be running the "exhaust" into a radiator like loop in my livingroom to double tap to keep myself warm in the winter as well as keeping my PC cooled.
Now alternatively I've been considering just running the most stupid water cooling loop, running mineral oil instead of water probably. I have some IC units from marine diesel engines I can use, all brass units, designed for using seawater to cool the charge air, alternatively I have some aluminum IC units from semi's I can modify to do the job. I want to run the plumbing through my outer walls in the house and have the rad outside, I have some small pumps that are high flow low pressure, something like 0.2-0.6 bar, that are pretty quiet. Again I suspect that I'd be running into condensation issues.
I'm not all that bothered about there being some noise since I always listen to some music or something when I'm on my PC anyway, and I normally at least hibernate it for the night so the cooling would be shut down. The PC lives in my bedroom.
Yeah, I have some other ideas but those would require me to re-wire the entire aparment complex and installing a pretty big diesel generator or something, so those are pretty much out of the question, also I'd need to get my hands on considerable ammounts of ammonia and some pretty huge evaporators... Well yeah anyway, please shoot these ideas down.
Why would you want to run mineral oil instead of water? The heat transfer properties of  mineral oil are vastly inferior to those of water. If you were to immerse the PC in it's entirety in mineral oil however....
If you really want to build something, you should try and design your own heat pipe. That would be fucking rad.
run your system in lava
Well, I guess I could do that, but really I'd rather trust in someone who has some actual experience in designing those things.
I just don't like water very much. I might have been thinking of a synthetic oil, pretty sure we had some oil that was designed for use as a coolant at work at some point. It is entirely possible that I'm mixing it up with a machining tool coolant of some description though.
Although googling it there appear to be several brands, including Mobil, that have "Cooling Oil", how legit those are I don't know, and what qualities they have I don't know.
Again, these are just ideas I've had, I haven't really made an effort to finalize any of them really, hell I still don't have the case I want as a permanent residence for my parts either.
I live too far away from any kind of fault line/volcano and I don't have a dril bit that is long enough to get to any lava.
Turn a can of compressed air upside down.
here's something to tickle your brain. Freon CPU Cooling.  They make there own condenser and everything.  Pretty awesome I thought when I first saw it.
If you've seen it before ignore this message.
Yeah, that's the kind of thing I was going for with the old refigerator unit, I can't remember if the one I have was pulled from a fridge or a freezebox.
Well the simple answer is to just have your condenser (don’t think big think small) controlled by a micro controller. Then you can just turn off the condenser, once you are reach near, dew point temperature (So a good idea would be to keep it about 10C above room temperature, you don’t have to have your system freezing, you just need it stable).
You also have to remember Mineral oil is used, more as lubricant, than a Coolent, it’s why your car radiator doesn’t use oil (their are exceptions to that at very cold temperatures you need a thicker liquid).Oil is great because it’s adaptable it works in lots of different temperatures. However unless you are overclocking to insane none day to day levels, you PC system might not even be able to run (if you go into minus numbers you CPU might reach the cold bug, I don’t remember the exact numbers but I expect it changes from cpu to cpu and your more than able to google that, as my knowledge is very out of date on that).
PC cooling is different from pretty much any industry as we only have one focus and have very tightly controlled conditions. You coolant isn’t needing to deal with 200C to -50C, it’s meant to deal with temperatures in the ranges of the water really. Water is simply the best (Pure water, or de-ionised) are non-conductive anyway, aslong as you refresh this liquid you won’t have any problems at all anyway. This is why in most temperate countries car radiator fluid is even water based (even with their much higher demands for large heat tolerances). So if your not going to bother with just de-ionised water I would suggest, car radiator fluid as it will give you the best chance of a workable fluid that will actually cool your system effectively.
The golden rule with cooling is computer controlled, if your going down this route. As otherwise you’ll be fighting with condensation the whole time. Also make sure you have you condenser properly isolated from you main system that way you have essentially made yourself a waterchiller, or you could go crazy and looking into phase change cooling but yea that area of cooling is just nuts.
My idea is straight up ridiculous stupid.
Glass tubing water cooling loop, glass radiators…mercury as coolant. Would need a custom pump to power it.
This topic is now closed. New replies are no longer allowed.
Guys… Oct’ 13…
