Hello everyone.
I have lost my damn mind. I have 99.9% made my way to adopting Ubuntu, specifically Ubuntu MATE 22.04 LTS. There is one crippling factor left, and that is connecting an xbox one controller via bluetooth.
I have tried xboxdrv via sudo apt install xboxdrv
but get an error message of:
[email protected]:~$ sudo systemctl start xboxdrv.service
Job for xboxdrv.service failed because of unavailable resources or another system error.
See "systemctl status xboxdrv.service" and "journalctl -xeu xboxdrv.service" for details.
[email protected]:~$ systemctl status xboxdrv.service
Ă— xboxdrv.service - Xbox controller driver daemon
Loaded: loaded (/etc/systemd/system/xboxdrv.service; enabled; vendor preset: enabled)
Active: failed (Result: resources)
CPU: 0
Jun 16 18:36:33 wwed-Z590-AORUS-MASTER systemd[1]: Failed to start Xbox controller driver daemon.
Jun 16 18:46:49 wwed-Z590-AORUS-MASTER systemd[1]: xboxdrv.service: Failed to load environment files: No such file or directory
Jun 16 18:46:49 wwed-Z590-AORUS-MASTER systemd[1]: xboxdrv.service: Failed to run 'start-pre' task: No such file or directory
Jun 16 18:46:49 wwed-Z590-AORUS-MASTER systemd[1]: xboxdrv.service: Failed with result 'resources'.
Jun 16 18:46:49 wwed-Z590-AORUS-MASTER systemd[1]: Failed to start Xbox controller driver daemon.
Jun 16 18:49:39 wwed-Z590-AORUS-MASTER systemd[1]: /etc/systemd/system/xboxdrv.service:7: PIDFile= references a path below legacy directory /var/run/, updating /var/run/xboxdrv.pid →>
Jun 16 18:49:48 wwed-Z590-AORUS-MASTER systemd[1]: xboxdrv.service: Failed to load environment files: No such file or directory
Jun 16 18:49:48 wwed-Z590-AORUS-MASTER systemd[1]: xboxdrv.service: Failed to run 'start-pre' task: No such file or directory
Jun 16 18:49:48 wwed-Z590-AORUS-MASTER systemd[1]: xboxdrv.service: Failed with result 'resources'.
Jun 16 18:49:48 wwed-Z590-AORUS-MASTER systemd[1]: Failed to start Xbox controller driver daemon.
I have tried
sudo apt install sysfsutils
sudo nano /etc/sysfs.conf
place the following at the end of the file. "/module/bluetooth/parameters/disable_ertm=1"
The controller either outright does not connect or “connects” then disconnects in a rolling cycle or "connects but the controller is still in pairing mode.
Can someone help me so I can finally transition away from windows!
Best,
WWED
