[SOLVED] VLC stutters on second monitor
Hello! I want to share some information that solved the issue I had on my Windows 11. I couldn’t find information about it on the internet and sorta stumbled upon the solution myself.
Basically my VLC or any video playback program would run at lower framerate and drop even more frames along with already said framerate. I tried the usual Windows power profile settings, VLC fixes, such as hardware acceleration, codec changes, allowing bigger cache size etc. None of that helped. I also won’t link any of those since there’s like a million forum posts and videos about how to try any of those solutions that could definitely be of use for someone else.
In my case I had to disable an option called “Hardware-accelerated GPU scheduling.” I restarted the PC right after as it also called for it and what do you know, it’s perfect now. I’m guessing the setting works different on the hardware you have and generation of it. While all the components in my PC are in the supported list for 11, something must still cause funny business with it.
TLDR:
I had to disable an option called “Hardware-accelerated GPU scheduling.” If that doesn’t work for someone else, look into other VLC stutter fixes, such as increasing cache, changing hardware acceleration options around or changing codecs. The option I used is visible on following screenshot.
I hope a post like this is fine along with the categories and everything I set in place.
Worked well for my GeForce RTX 5080 connected in HDMI with my Projector. Thanks a lot !
You’re welcome and also welcome to the forum!
Also smplayer is a fantastic video player
It was the problem for me with any sort of playback software now that I recall. It happened on Youtube in Firefox as well but it wasn’t nearly as bad.
This truly DOES WORK and im amazed. Again same story 3080 ti and the secondary monitor not the primary and not just VLC but all video players especially when gaming on Windows 11… Turn it OFF and you are good to go. Thank you for this post I owe you
:love_you_gesture::love_you_gesture::love_you_gesture::kissing_heart:
