So I have a Windows 10 host machine with VirtualBox on it. It has a Windows 10 guest. The Windows 10 guest has a USB mouse and keyboard passedthrough to it. The cursor works, but is invisible while using the mouse that is passedthrough.
Googling this issue comes up with problems caused by 3D acceleration and is usually solved by disabling and re-enabling mouse integration. This does not solve my issue.
The idea is that two people can use one computer to do things with two separate peripherals (mouse, keyboard, displays). Everything works about this except the mouse cursor showing up.
Any help is appreciated.
Edit:
Whenever I grab a window by the title bar, then drag it, the cursor appears while I'm doing that. But then disappears as soon as I stop. This is bizarre...
I swear I had that info in the OP, but re-reading it, I must've imagined that.
Yes, the guest additions are there. I need to clarify I don't want to use the host's mouse. I want to use a USB mouse that I've passed through to the guest only.
This setup works fine, except I can't see the cursor on the Virtual Machine. It's there if I drag a window. It's there and works if I click things, but it is invisible.
I'm gonna assume you meant "host and VM".
On VM, default (the middle of the slow->fast slider in Mouse Options on Windows 10).
The host shouldn't matter because I'm not using it's mouse to do this. I realize the mouse I'm passing through is being passed through by the host, but settings I change on the host does not affect the passedthrough mouse's characteristics.
The cursor wasn't visible before I added Guest Additions. I'm limited in my ability to test this as I'm using Teamviewer atm and the person needs to use the host for work purposes. I can remote into the guest VM with Teamviewer and the cursor responds accurately.
Hey, end game for me with this setup is using linux as the host with two Windows guests, but I can't do that at the moment.
It may be. I wouldn't know how to test that though. I've never had this issue before in a non-virtualized system.
The cursor appears and acts correctly when remoting in. At the moment I have it set to invert on background, and through TV, it is definitely inverting correctly.
Hmm, not sure what I did to get it to work, but it's working now according to people who are there. Wonderful.
Either switching the mouse to Inverted mode did it, or removing->adding the USB device did it. I did see it install some drivers for the Keyboard/Mouse, so that may have done it.
Funny that someone else revived this thread, but I just installed Guest Additions and it caused my mouse to become invisible, was hoping it was just something stupid that I was missing
Edit: the only thing I’ve found that helps is uninstalling Guest Additions (Windows 10 host, Windows 10 VM)
