I'm going to help a friend to set up some stuff for streaming overseas and I need to use TeamViewer. But I ran into this problem when installing it. How do I solve it?
at first it looks like teamviewer was already installed and the package you have is trying to downgrade it to an older version.
you can install it with this>
https://www.teamviewer.com/en/download/linux.aspx
use the 32/64 multiarch
run it with the software installer. at least this is how i installed mine
okay it looks like the teamview service isnt running in a terminal type in
teamviewer --daemon status
if that says it is off then you can do
teamviewer --daemon start
and teamviewer --daemon enable (this one should be on already it is to start teamviewer on boot) use "disable" if you don't want this.
Alright, it's up and running! =D Thanks man!
No problem. :) you should put solved in the title, helps others out if they have issues they can try this.
