the only option I have under CPU SOC is Offset. I can’t manually set it.
What? Just write a number into the field and hit enter. That doesn’t work?
No that doesn’t work. The options are AUTO and OFFSET, no way to enter a number.
Huh, well … don’t spend to much time in the UEFI then, I guess.
Hopefully it’s just displayed wrong.
Yeah it seems like B-die is still the best way to go to be sure.
Sorry I can’t really help.
No problem, thanks for all your suggestions.
I contacted ASUS and apparently this MOBO has RAM slots A2 & B2 as primary not A1 & B1. So I put the RAM in the Primary slots and boom full speed.
Thank you for suggesting I reach out to the manufacturer.
Solved moved Ram to Slots A2 and B2 and then ram hit speed correctly
