Hello friends,
For some reason, after every restart, I need to plug in my headphone jack and then plug it back out in order to get my speakers (line out) to work. Does anyone know where I should start looking to diagnose/remedy this?
I have not always had this problem, I frequently run dnf update
and had several kernel updates without problem. This might be a factor. Not sure.
I have supplied some info below, in the hopes that it might be useful. If you need additional info I will get more!
Thanks in advance.
System info:
Audio set-up:
- USB audio dongle in the back (Not in use right now)
- Headphone jack on front panel (Used to re-plug headphones)
- Line-out on back panel (Connected to speakers)
# lspci -nnk
output:
#Audio controller on motherboard
0c:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller [1022:1457]
Subsystem: ASUSTeK Computer Inc. Device [1043:8723]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
System info:
- Motherboard:
ASUS ROG STRIX B350-F GAMING
- Operating system:
Fedora 30
uname -a
output (trimmed):Linux 5.1.17-300.fc30.x86_64 #1 x86_64 GNU/Linux
Screenshot of $ pavucontrol
