So recently I switched to Intel and have noticed a strange occurrence with my machine. When I press the power button to shutdown the system all the screens go into sleep like normal, but fans and HDD's continue spinning and AIO still has pump light on. PRESSING POWER BUTTON AGAIN DOES NOTHING
I does the same thing when I restart it as well
I have scoured the internet to no avail
specs link is in profile
after further research this appears to be an issue with windows 10
That's the quickest solution to solving any problems with windows
Should split your hard drive into 2 partitions, one for the OS and one for long term storage, that way you only ever have to wipe one when you need to reinstall, also you should have a back up of your stuff anyways
All you'd do is point steam to where that library folder is, and unplug the drives so there's no chance of wiping them accidentally during reinstallation
