This is mostly just complaining but I can’t seem to get networkmanager to make my wireguard vpn work at all. using wireguard’s tools (wg-quick) works fine though.
I don’t know if im missing a setting somewhere or networkmanager needs specific, different settings than the ones that work everywhere else but its really annoying.
If anyone knows why this is a thing please let me know…
I remember banging my head over this extensively once upon a time…I can’t recall the exact fix, but I think I had to uncheck the automatic connection stuff for the Wireguard connection, which made it a non-starter for me. Always-on VPN is a must for me.
I know it was an open issue on, I think the NetworkManager issue tracker, but I’m not finding it at the moment. I’ll update here if I stumble upon it again.
Sadly, the answer for me ended up being to just use Tailscale…my life has been so much better and easier since then. If they ever go to shit…I’ll mess with Headscale, I guess.
Headscale’s not bad at all! I keep an instance running for when I’m on the rare networks that block tailscale successfully - headscale usually still works.
