Overveiw of my Configuration
I am on the latest version of Proxmox 7 nodes total, 3 dedicated to just host CEPH, no VM or LXC, I have 3 CEPH pools divided int devices class; HDD, SSD, NVME. The one I need help with is the HDD pool in a 2/3 configuration and where I do my bulk storage via unprivileged passthrough over cephfs.
The boot SSD can be ignored completely and the NVME device can be ignored for now if they show up in any of the outputs I post.
Overview of my issue I am trying to resolve
Been stuck running in circles trying to get one of my CEPH nodes back online. Been at it for a few days between prompting an LLM, online communities, and hardware troubleshooting.
The TL;DR of my issue is as follows
1 of my nodes from a ceph 2/3 configuration isn’t picking the drives in LVM and ceph fails to set them to UP after a hardware change. They do, however show up in lsblk
The full details of my issue is as follows
A node failed to power back on after a routine update. Narrowed it down to either the motherboard or PSU. I went for the motherboard first since for the PSU; I don’t know if it was the redundant modules dying at the same time (highly unlikely for anyone who doesn’t have my bad luck), the the power distribution board they slot into, or possibly faulty cables to the motherboard/CPU. Turned out motherboard was the wrong choice, since I wasn’t sure which part of the PSU was the issue, I just bought a new (used) chassis, and shifted my mentality from its wasting money to I need to add a fourth node in the future anyways to make it a 3/4 instead of a 2/3, I’ll just hang onto it for that. I decided to keep the new motherboard in, one other thing that changed, instead of running 4 SFF-8643 from each HBA to each backplane, this chassis came with the original wiring, which only ran 2 from the HBA to the backplane (I think they split IIRC), mainly because those chassis are a pain in the ass to rewire. I kept both HBA’s though and split the backplanes 2 - 2 between the 2 HBA’s
The meat and potatos
what I’ve found on my own so far
blkid shows the devices
Output of blkid
/dev/sdy: UUID="Sf56nw-UHtc-fagE-jC0t-3JVl-I3EV-qve17p" TYPE="LVM2_member"
/dev/mapper/ceph--74f4d41b--17bd--40fc--85db--cc911a9c62e3-osd--block--d67facbc--a33a--47ad--9149--95b29552bf50: TYPE="ceph_bluestore"
/dev/sdf: UUID="gTYMNV-gYkg-YtkG-Txt7-DjUT-2eOF-f1mAZ7" TYPE="LVM2_member"
/dev/mapper/ceph--d402377f--ad20--4b78--a64f--3dab06e56717-osd--block--96dbfa75--1f2d--459b--9bfe--e23332b3ce2a: TYPE="ceph_bluestore"
/dev/sdab: UUID="NdSaeg-xof6-of1x-wffq-33ky-CW8v-ed5Kjp" TYPE="LVM2_member"
/dev/nvme0n1: UUID="ff9ut5-wZHj-Ubkw-e5I8-1Gd9-RPD5-GxIk71" TYPE="LVM2_member"
/dev/sdo: UUID="D76b9G-D7L7-hcnM-sujM-e5EM-ZU0o-1zBBxC" TYPE="LVM2_member"
/dev/sdw: UUID="QGzbN2-CEwl-fXmn-blBM-v193-slac-ZoIuZ4" TYPE="LVM2_member"
/dev/sdd: UUID="gcImln-kprW-u6yy-bvxY-Hsif-A2VH-GoNLE1" TYPE="LVM2_member"
/dev/mapper/ceph--3fc05ed9--59d8--49e3--bc8d--298c9a0e9b23-osd--block--b1432435--d44c--4c2b--b796--54faa4d257e7: TYPE="ceph_bluestore"
/dev/sdm: UUID="NdSaeg-xof6-of1x-wffq-33ky-CW8v-ed5Kjp" TYPE="LVM2_member"
/dev/sdu: UUID="gTYMNV-gYkg-YtkG-Txt7-DjUT-2eOF-f1mAZ7" TYPE="LVM2_member"
/dev/sdb2: LABEL_FATBOOT="EFI" LABEL="EFI" UUID="C0F0-1E54" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="8b2d1806-70e8-4029-917d-507db741940d"
/dev/sdb3: LABEL="rpool" UUID="14862405257286652260" UUID_SUB="11027083028655113868" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="7f8f63a3-7e54-4249-9907-65aba8f6e53f"
/dev/mapper/ceph--7deda356--de11--4742--a773--71980f6bd84a-osd--block--0d4a4621--f087--4c1c--97f6--753b88427e5c: TYPE="ceph_bluestore"
/dev/sdk: UUID="8MCpO9-YwlG-8FNB-Wbgu-ueSn-198L-YfB2Ol" TYPE="LVM2_member"
/dev/mapper/ceph--2662cb97--3c87--49fc--9ceb--8eac077054b2-osd--block--caaf0c96--e90e--46b8--9a49--cf84260b94e4: TYPE="ceph_bluestore"
/dev/sds: UUID="gcImln-kprW-u6yy-bvxY-Hsif-A2VH-GoNLE1" TYPE="LVM2_member"
/dev/mapper/ceph--5909443b--69ac--4d66--899c--f6d7345db3e5-osd--block--2f7003ec--e2cb--4ce6--8420--ca67c196bf8f: TYPE="ceph_bluestore"
/dev/sdi: UUID="e6pj7g-PCVU-W3Xp-fXcN-jEbW-wI1S-0v5Acv" TYPE="LVM2_member"
/dev/mapper/ceph--2db90f9e--74de--46a0--aaa9--7ade4746c96f-osd--block--6995b8b2--8d94--47f0--becf--820dac70e766: TYPE="ceph_bluestore"
/dev/sdq: UUID="Sg35N6-3AZM-Tnf4-vAVn-ldwf-Zfqy-P8wEA9" TYPE="LVM2_member"
/dev/sdae: UUID="Wzs4ka-Ji0n-q4rc-zQzy-5bsc-MMKk-apshTO" TYPE="LVM2_member"
/dev/sdz: UUID="8MCpO9-YwlG-8FNB-Wbgu-ueSn-198L-YfB2Ol" TYPE="LVM2_member"
/dev/mapper/ceph--7af30a0d--fba9--48fd--ae7d--6c7ee2d96461-osd--block--8a5813b8--c948--4e14--9861--af917047ab34: TYPE="ceph_bluestore"
/dev/sdg: UUID="aqKoCv-rX6z-o2lq-haV7-qOQh-edXa-R1gpHR" TYPE="LVM2_member"
/dev/mapper/ceph--b9e1fb6c--1e20--4db7--8527--a1ee295d7489-osd--block--aacdc12a--2f0f--4a75--8542--9a613c0f8d26: TYPE="ceph_bluestore"
/dev/sdac: UUID="hJxcYj-four-rpis-Qir8-dvCW-GTd9-eAzsSp" TYPE="LVM2_member"
/dev/sdx: UUID="e6pj7g-PCVU-W3Xp-fXcN-jEbW-wI1S-0v5Acv" TYPE="LVM2_member"
/dev/mapper/ceph--778c730e--e642--4c96--82ce--2fdb2e4f4082-osd--block--34d76c55--f2f6--4225--b03a--11b1a44a8e4a: TYPE="ceph_bluestore"
/dev/sde: UUID="MEDGNJ-u32d-ndMy-ilB1-m9Ax-DWkY-Ye9Gy5" TYPE="LVM2_member"
/dev/sdaa: UUID="Ayah4K-ceTm-HSiM-amN6-sdVJ-WZXp-sMfy2u" TYPE="LVM2_member"
/dev/mapper/ceph--a20745fa--d748--4c33--acc0--01361d6cbda4-osd--block--03728b9e--d559--4fcc--a7b9--1bc7abb03380: TYPE="ceph_bluestore"
/dev/sdn: UUID="hJxcYj-four-rpis-Qir8-dvCW-GTd9-eAzsSp" TYPE="LVM2_member"
/dev/sdv: UUID="aqKoCv-rX6z-o2lq-haV7-qOQh-edXa-R1gpHR" TYPE="LVM2_member"
/dev/sdc: UUID="vg0wUM-EXBK-Uh6K-T3xK-K7P3-q2ld-3SyTb7" TYPE="LVM2_member"
/dev/mapper/ceph--11d04bdd--1f69--4be7--8fc9--e0c28fb72d11-osd--block--a9b3c0d5--c437--4743--aa6f--64205d8b8633: TYPE="ceph_bluestore"
/dev/sdl: UUID="Ayah4K-ceTm-HSiM-amN6-sdVJ-WZXp-sMfy2u" TYPE="LVM2_member"
/dev/sdt: UUID="MEDGNJ-u32d-ndMy-ilB1-m9Ax-DWkY-Ye9Gy5" TYPE="LVM2_member"
/dev/sda2: UUID="1203-0CDA" BLOCK_SIZE="512" TYPE="vfat" PARTUUID="942d4d84-7171-4137-aa90-ca3ff1856a9b"
/dev/sda3: LABEL="rpool" UUID="14862405257286652260" UUID_SUB="3339468819426860827" BLOCK_SIZE="4096" TYPE="zfs_member" PARTUUID="5e5efbb8-fc10-4cbb-9d6e-a014502267c7"
/dev/mapper/ceph--6a73260a--8b83--427c--a953--98de36a78060-osd--block--bdaeb37b--0491--46c5--b05c--a8770a4964c0: TYPE="ceph_bluestore"
/dev/sdj: UUID="Sf56nw-UHtc-fagE-jC0t-3JVl-I3EV-qve17p" TYPE="LVM2_member"
/dev/mapper/ceph--a972216d--80d7--48f1--8d85--a2a9df5b9261-osd--block--4576958b--03f6--49cd--ab0c--405b1f942c7b: TYPE="ceph_bluestore"
/dev/sdr: UUID="vg0wUM-EXBK-Uh6K-T3xK-K7P3-q2ld-3SyTb7" TYPE="LVM2_member"
/dev/sdaf: UUID="Sg35N6-3AZM-Tnf4-vAVn-ldwf-Zfqy-P8wEA9" TYPE="LVM2_member"
/dev/mapper/ceph--095653a2--d894--4713--a98b--77439400987d-osd--block--43df5e31--450f--4914--bb80--078628e85f1f: TYPE="ceph_bluestore"
/dev/sdh: UUID="QGzbN2-CEwl-fXmn-blBM-v193-slac-ZoIuZ4" TYPE="LVM2_member"
/dev/mapper/ceph--d8049b27--52a7--4478--85fe--117cf8cba9d2-osd--block--31c0f65e--ad51--46df--931f--483c6c0324aa: TYPE="ceph_bluestore"
/dev/sdp: UUID="Wzs4ka-Ji0n-q4rc-zQzy-5bsc-MMKk-apshTO" TYPE="LVM2_member"
/dev/sdad: UUID="D76b9G-D7L7-hcnM-sujM-e5EM-ZU0o-1zBBxC" TYPE="LVM2_member"
/dev/sdb1: PTUUID="172b2f43-edef-4c65-a3b8-9aa1f396e289" PTTYPE="gpt" PARTUUID="5b9595d2-6b99-4011-959f-fc42a15e32ff"
/dev/sda1: PARTUUID="3b00b8b0-ecfa-4ff4-8a8c-ec18ef1cef0b"
here is the output of lsblk -o NAME,SIZE,TYPE,FSTYPE,PARTLABEL,UUID
NAME SIZE TYPE FSTYPE PARTLABEL UUID
sda 119.2G disk
|-sda1 1007K part
|-sda2 1G part vfat 1203-0CDA
`-sda3 118.2G part zfs_member 14862405257286652260
sdb 119.2G disk
|-sdb1 1007K part
|-sdb2 1G part vfat C0F0-1E54
`-sdb3 118.2G part zfs_member 14862405257286652260
sdc 10.9T disk LVM2_member vg0wUM-EXBK-Uh6K-T3xK-K7P3-q2ld-3SyTb7
`-ceph--b9e1fb6c--1e20--4db7--8527--a1ee295d7489-osd--block--aacdc12a--2f0f--4a75--8542--9a613c0f8d26
10.9T lvm ceph_bluestore
sdd 10.9T disk LVM2_member gcImln-kprW-u6yy-bvxY-Hsif-A2VH-GoNLE1
`-ceph--095653a2--d894--4713--a98b--77439400987d-osd--block--43df5e31--450f--4914--bb80--078628e85f1f
sde 10.9T disk LVM2_member MEDGNJ-u32d-ndMy-ilB1-m9Ax-DWkY-Ye9Gy5
sdf 10.9T disk LVM2_member gTYMNV-gYkg-YtkG-Txt7-DjUT-2eOF-f1mAZ7
sdg 10.9T disk LVM2_member aqKoCv-rX6z-o2lq-haV7-qOQh-edXa-R1gpHR
`-ceph--7af30a0d--fba9--48fd--ae7d--6c7ee2d96461-osd--block--8a5813b8--c948--4e14--9861--af917047ab34
sdh 10.9T disk LVM2_member QGzbN2-CEwl-fXmn-blBM-v193-slac-ZoIuZ4
`-ceph--11d04bdd--1f69--4be7--8fc9--e0c28fb72d11-osd--block--a9b3c0d5--c437--4743--aa6f--64205d8b8633
sdi 10.9T disk LVM2_member e6pj7g-PCVU-W3Xp-fXcN-jEbW-wI1S-0v5Acv
`-ceph--d8049b27--52a7--4478--85fe--117cf8cba9d2-osd--block--31c0f65e--ad51--46df--931f--483c6c0324aa
sdj 10.9T disk LVM2_member Sf56nw-UHtc-fagE-jC0t-3JVl-I3EV-qve17p
`-ceph--3fc05ed9--59d8--49e3--bc8d--298c9a0e9b23-osd--block--b1432435--d44c--4c2b--b796--54faa4d257e7
sdk 10.9T disk LVM2_member 8MCpO9-YwlG-8FNB-Wbgu-ueSn-198L-YfB2Ol
`-ceph--7deda356--de11--4742--a773--71980f6bd84a-osd--block--0d4a4621--f087--4c1c--97f6--753b88427e5c
sdl 10.9T disk LVM2_member Ayah4K-ceTm-HSiM-amN6-sdVJ-WZXp-sMfy2u
`-ceph--2db90f9e--74de--46a0--aaa9--7ade4746c96f-osd--block--6995b8b2--8d94--47f0--becf--820dac70e766
sdm 10.9T disk LVM2_member NdSaeg-xof6-of1x-wffq-33ky-CW8v-ed5Kjp
`-ceph--a972216d--80d7--48f1--8d85--a2a9df5b9261-osd--block--4576958b--03f6--49cd--ab0c--405b1f942c7b
sdn 10.9T disk LVM2_member hJxcYj-four-rpis-Qir8-dvCW-GTd9-eAzsSp
sdo 10.9T disk LVM2_member D76b9G-D7L7-hcnM-sujM-e5EM-ZU0o-1zBBxC
`-ceph--d402377f--ad20--4b78--a64f--3dab06e56717-osd--block--96dbfa75--1f2d--459b--9bfe--e23332b3ce2a
sdp 10.9T disk LVM2_member Wzs4ka-Ji0n-q4rc-zQzy-5bsc-MMKk-apshTO
`-ceph--a20745fa--d748--4c33--acc0--01361d6cbda4-osd--block--03728b9e--d559--4fcc--a7b9--1bc7abb03380
sdq 10.9T disk LVM2_member Sg35N6-3AZM-Tnf4-vAVn-ldwf-Zfqy-P8wEA9
`-ceph--6a73260a--8b83--427c--a953--98de36a78060-osd--block--bdaeb37b--0491--46c5--b05c--a8770a4964c0
sdr 10.9T disk LVM2_member vg0wUM-EXBK-Uh6K-T3xK-K7P3-q2ld-3SyTb7
sds 10.9T disk LVM2_member gcImln-kprW-u6yy-bvxY-Hsif-A2VH-GoNLE1
sdt 10.9T disk LVM2_member MEDGNJ-u32d-ndMy-ilB1-m9Ax-DWkY-Ye9Gy5
`-ceph--74f4d41b--17bd--40fc--85db--cc911a9c62e3-osd--block--d67facbc--a33a--47ad--9149--95b29552bf50
sdu 10.9T disk LVM2_member gTYMNV-gYkg-YtkG-Txt7-DjUT-2eOF-f1mAZ7
`-ceph--5909443b--69ac--4d66--899c--f6d7345db3e5-osd--block--2f7003ec--e2cb--4ce6--8420--ca67c196bf8f
sdv 10.9T disk LVM2_member aqKoCv-rX6z-o2lq-haV7-qOQh-edXa-R1gpHR
sdw 10.9T disk LVM2_member QGzbN2-CEwl-fXmn-blBM-v193-slac-ZoIuZ4
sdx 10.9T disk LVM2_member e6pj7g-PCVU-W3Xp-fXcN-jEbW-wI1S-0v5Acv
sdy 10.9T disk LVM2_member Sf56nw-UHtc-fagE-jC0t-3JVl-I3EV-qve17p
sdz 10.9T disk LVM2_member 8MCpO9-YwlG-8FNB-Wbgu-ueSn-198L-YfB2Ol
sdaa 10.9T disk LVM2_member Ayah4K-ceTm-HSiM-amN6-sdVJ-WZXp-sMfy2u
sdab 10.9T disk LVM2_member NdSaeg-xof6-of1x-wffq-33ky-CW8v-ed5Kjp
sdac 10.9T disk LVM2_member hJxcYj-four-rpis-Qir8-dvCW-GTd9-eAzsSp
`-ceph--2662cb97--3c87--49fc--9ceb--8eac077054b2-osd--block--caaf0c96--e90e--46b8--9a49--cf84260b94e4
sdad 10.9T disk LVM2_member D76b9G-D7L7-hcnM-sujM-e5EM-ZU0o-1zBBxC
sdae 10.9T disk LVM2_member Wzs4ka-Ji0n-q4rc-zQzy-5bsc-MMKk-apshTO
sdaf 10.9T disk LVM2_member Sg35N6-3AZM-Tnf4-vAVn-ldwf-Zfqy-P8wEA9
nvme0n1 894.3G disk LVM2_member ff9ut5-wZHj-Ubkw-e5I8-1Gd9-RPD5-GxIk71
`-ceph--778c730e--e642--4c96--82ce--2fdb2e4f4082-osd--block--34d76c55--f2f6--4225--b03a--11b1a44a8e4a
894.3G lvm ceph_bluestore
dmsetup table "<device-id>" output
device-mapper: table ioctl on ceph-b9e1fb6c-1e20-4db7-8527-a1ee295d7489 failed: No such device or address
Command failed.
ceph-volume lvm list || true only shows the 1 NVME SSD
====== osd.46 ======
[block] /dev/ceph-778c730e-e642-4c96-82ce-2fdb2e4f4082/osd-block-34d76c55-f2f6-4225-b03a-11b1a44a8e4a
block device /dev/ceph-778c730e-e642-4c96-82ce-2fdb2e4f4082/osd-block-34d76c55-f2f6-4225-b03a-11b1a44a8e4a
block uuid KcdEnZ-Wwhs-aS7X-Csob-pBNh-bQP6-6juMo1
cephx lockbox secret
cluster fsid 50824a88-c4d8-40e9-aa4f-5e10c2b7c5d2
cluster name ceph
crush device class nvme
encrypted 0
osd fsid 34d76c55-f2f6-4225-b03a-11b1a44a8e4a
osd id 46
osdspec affinity
type block
vdo 0
with tpm 0
devices /dev/nvme0n1
I think what I need to is restore LVM from backup using
pvcreate --force --uuid "<UUID>" --restorefile /etc/lvm/backup/<ceph-id> /dev/sdc
However I get this error as an output:
WARNING: Couldn't find device with uuid vg0wUM-EXBK-Uh6K-T3xK-K7P3-q2ld-3SyTb7.
Can't initialize physical volume "/dev/sdc" of volume group "ceph-b9e1fb6c-1e20-4db7-8527-a1ee295d7489" without -ff
/dev/sdc: physical volume not initialized.
Basically the SAS3 drives associated with CEPH are refusing to initialize for some reason, and I’m not sure why or how to get them to initialize. Any help would be massively appreciated. There is definitely some other things I’ve tried that I’ve left out, but everything I’ve tried so far is a jumbled mess so I apologize for that in advance, it’s just been very stressful trying to resolve this issue since I don’t have access to anything on there, my stress outlets like my media server are just down until I get it back up and running.
