[Solved] Lutris Permission Error
One more thing I forgot about, the .wine folder obviously… sorry. Delete it or chown it and try one more time.
Dialog-warning.svg NEVER run Wine as root! Doing so gives Windows programs (and viruses) full access to your computer and every piece of media attached to it. Running with sudo also has these same risks but with the added bonus of breaking the permissions on your ~/.wine folder in the process. If you have run Wine with sudo you need to fix the permission errors as described in the next question, and then run winecfg to set Wine up again. You should always run Wine as the normal user you use to login.
For Linux systems, all ideas that Wine needs root can be solved through Posix Capabilities or Posix File Capabilities or correcting other security settings.
As far as Windows programs are concerned, you are running with administrator privileges. If an application complains about a lack of administrator privileges, file a bug; running Wine as root probably won’t help.
I fixed the .wine folder and it finished “installing”, but it does not run. when launched i just stops immediately without launching origin or anything.
info:  Game: Origin.exe
info:  DXVK: v0.96
info:  Found config file: /mnt/MintData/Lutris/Games/battlefield-1/dxvk.conf
info:  Effective configuration:
info:    dxgi.customVendorId = 10de
warn:  OpenVR: Failed to locate module
wine: Call from 0x7bc7d969 to unimplemented function vulkan-1.dll.vkGetInstanceProcAddr, aborting
wine: Unimplemented function vulkan-1.dll.vkGetInstanceProcAddr called at address 0x7bc7d969 (thread 0009), starting debugger...
Unhandled exception: unimplemented function vulkan-1.dll.vkGetInstanceProcAddr called in 32-bit code (0x7bc7d969).
Register dump:
 CS:0023 SS:002b DS:002b ES:002b FS:0063 GS:006b
 EIP:7bc7d969 ESP:0032d818 EBP:0032d88c EFLAGS:00000216(   - --  I   -A-P- )
 EAX:6f5955a2 EBX:7bd25000 ECX:07d9cb10 EDX:6f592460
 ESI:0032d830 EDI:0032d918
Stack dump:
0x0032d818:  ffffffff 4ce02700 7bc7d943 6f52e3c5
0x0032d828:  0032d850 77328000 80000100 00000001
0x0032d838:  00000000 7bc7d969 00000002 6f595590
0x0032d848:  6f5955a2 772bc170 07d90000 00000000
0x0032d858:  00000010 6f592460 6f5376e4 772bc126
0x0032d868:  0032d888 772bcc07 6f592460 6f51eac0
Backtrace:
=>0 0x7bc7d969 (0x0032d88c)
  1 0x07d8000f (0x0032dac8)
  2 0x6f404f29 EntryPoint+0x3b78() in dxgi (0x0032db24)
  3 0x6f405724 EntryPoint+0x4373() in dxgi (0x0032db54)
  4 0x6f4058ef in dxgi (+0x58ee) (0x0032dbe4)
  5 0x07bd1967 EntryPoint+0xffffffff() in libglesv2 (0x0032dc68)
  6 0x07bd13df EntryPoint+0xffffffff() in libglesv2 (0x0032ddf0)
  7 0x07b19a40 EntryPoint+0xffffffff() in libglesv2 (0x0032de3c)
  8 0x07b1a361 EntryPoint+0xffffffff() in libglesv2 (0x0032de60)
  9 0x07ab35da EntryPoint+0xffffffff() in libglesv2 (0x0032df80)
  10 0x07b60d4d EntryPoint+0xffffffff() in libglesv2 (0x0032dfb8)
  11 0x078ef8a7 EntryPoint+0xffffffff() in qwindows (0x0032e108)
  12 0x671bfa68 EntryPoint+0xffffffff() in qt5core (0x0032e14c)
  13 0x032ae624 EntryPoint+0xffffffff() in qt5gui (0x0078ae40)
  14 0x0032e508 (0x65345838)
  15 0x65014950 EntryPoint+0xffffffff() in qt5widgets (0x65013690)
  16 0xa8d98b53 (0x0424448b)
  17 0xe88be8ff (0xfffeb48d)
0x7bc7d969: addl	$12,%esp
Modules:
Module	Address			Debug info	Name (101 modules)
PE	  330000-  344000	Deferred        vcruntime140
PE	  350000-  354000	Deferred        api-ms-win-crt-runtime-l1-1-0
PE	  360000-  363000	Deferred        api-ms-win-crt-heap-l1-1-0
PE	  370000-  374000	Deferred        api-ms-win-crt-stdio-l1-1-0
PE	  380000-  383000	Deferred        api-ms-win-crt-locale-l1-1-0
PE	  390000-  395000	Deferred        api-ms-win-crt-math-l1-1-0
PE	  3a0000-  3a3000	Deferred        api-ms-win-crt-time-l1-1-0
PE	  3e0000-  3f5000	Deferred        qt5quickwidgets
PE	  400000-  700000	Deferred        origin
PE	  a30000- 3266000	Deferred        originclient
PE	 3270000- 380a000	Export          qt5gui
PE	 3810000- 3849000	Deferred        qt5webenginewidgets
PE	 3850000- 6ca2000	Deferred        qt5webenginecore
PE	 6cb0000- 6ce8000	Deferred        qt5positioning
PE	 6cf0000- 7032000	Deferred        qt5quick
PE	 7040000- 7061000	Deferred        qt5webchannel
PE	 7070000- 70c1000	Deferred        qt5printsupport
PE	 70d0000- 7183000	Deferred        qt5multimedia
PE	 7190000- 73b7000	Deferred        igo32
PE	 73c0000- 7540000	Deferred        libeay32
PE	 7540000- 7543000	Deferred        api-ms-win-crt-conio-l1-1-0
PE	 7550000- 757a000	Deferred        qt5websockets
PE	 7580000- 7590000	Deferred        qt5texttospeech
PE	 7590000- 75f5000	Deferred        ssleay32
PE	 78b0000- 7a41000	Export          qwindows
PE	 7a70000- 7a79000	Deferred        libegl
PE	 7a80000- 7d7a000	Export          libglesv2
PE	10000000-1006d000	Deferred        msvcp140
PE	4a800000-4a936000	Deferred        icuuc58
PE	4ad00000-4ad03000	Deferred        icudt58
PE	61000000-61031000	Deferred        qt5xml
PE	64000000-64126000	Deferred        qt5network
PE	65000000-654df000	Export          qt5widgets
PE	66000000-66361000	Deferred        qt5qml
PE	67000000-67543000	Export          qt5core
PE	6a540000-6a7b3000	Deferred        d3d11
PE	6f400000-6f5a3000	Export          dxgi
PE	77290000-772a5000	Deferred        msvcrt
PE	79690000-79699000	Deferred        opengl32
PE	797c0000-797ca000	Deferred        wined3d
PE	79a40000-79a48000	Deferred        vulkan-1
PE	7b420000-7b5e6000	Deferred        kernel32
PE	7b920000-7b925000	Deferred        d3d9
PE	7b9f0000-7b9f6000	Deferred        wintab32
PE	7ba10000-7ba15000	Deferred        dsound
PE	7ba60000-7ba79000	Deferred        setupapi
PE	7bad0000-7bad4000	Deferred        powrprof
PE	7bae0000-7bae4000	Deferred        wtsapi32
PE	7bb00000-7bb06000	Deferred        dwmapi
PE	7bb10000-7bbb5000	Deferred        comdlg32
PE	7bc40000-7bc57000	Deferred        ntdll
PE	7bd70000-7bd74000	Deferred        kerberos
PE	7bd90000-7bd9e000	Deferred        winspool
PE	7bdd0000-7bdd5000	Deferred        secur32
PE	7bf20000-7bf24000	Deferred        userenv
PE	7bf40000-7bf44000	Deferred        dhcpcsvc
PE	7bf50000-7bfcb000	Deferred        winmm
PE	7c010000-7c017000	Deferred        iphlpapi
PE	7c040000-7c048000	Deferred        netapi32
PE	7c070000-7c075000	Deferred        rsaenh
PE	7c0e0000-7c0e7000	Deferred        dnsapi
PE	7c100000-7c107000	Deferred        dbghelp
PE	7c160000-7c165000	Deferred        imagehlp
PE	7c1f0000-7c211000	Deferred        wininet
PE	7c270000-7c283000	Deferred        urlmon
PE	7c420000-7c42d000	Deferred        mpr
PE	7c9c0000-7c9e4000	Deferred        msxml3
PE	7caa0000-7caae000	Deferred        msxml
PE	7cd50000-7cd55000	Deferred        psapi
PE	7d140000-7d146000	Deferred        uxtheme
PE	7d5a0000-7d5a6000	Deferred        winex11
PE	7d630000-7d634000	Deferred        api-ms-win-core-fibers-l1-1-1
PE	7d640000-7d643000	Deferred        api-ms-win-core-synch-l1-2-0
PE	7d650000-7d655000	Deferred        bcrypt
PE	7d680000-7d6c6000	Deferred        crypt32
PE	7d750000-7d757000	Deferred        wintrust
PE	7d780000-7d786000	Deferred        imm32
PE	7d7b0000-7d7b4000	Deferred        usp10
PE	7d7f0000-7d844000	Deferred        comctl32
PE	7d930000-7d93a000	Deferred        aclui
PE	7d950000-7d956000	Deferred        shcore
PE	7d970000-7d982000	Deferred        shlwapi
PE	7d9e0000-7e2d6000	Deferred        shell32
PE	7e3c0000-7e3c3000	Deferred        api-ms-win-crt-utility-l1-1-0
PE	7e3d0000-7e3d3000	Deferred        api-ms-win-crt-environment-l1-1-0
PE	7e3e0000-7e3e3000	Deferred        api-ms-win-crt-filesystem-l1-1-0
PE	7e400000-7e405000	Deferred        api-ms-win-crt-multibyte-l1-1-0
PE	7e410000-7e414000	Deferred        api-ms-win-crt-convert-l1-1-0
PE	7e430000-7e434000	Deferred        api-ms-win-crt-string-l1-1-0
PE	7e450000-7e479000	Deferred        ucrtbase
PE	7e540000-7e547000	Deferred        ws2_32
PE	7e580000-7e58d000	Deferred        rpcrt4
PE	7e610000-7e63d000	Deferred        ole32
PE	7e760000-7e76e000	Deferred        oleaut32
PE	7e880000-7e886000	Deferred        jsproxy
PE	7e8a0000-7e8a7000	Deferred        winhttp
PE	7e8e0000-7e8e5000	Deferred        version
PE	7e900000-7e9f3000	Deferred        user32
PE	7eb00000-7eb0d000	Deferred        advapi32
PE	7eb80000-7eb8e000	Deferred        gdi32
PE	7eeb0000-7eeb3000	Deferred        wow64cpu
Threads:
process  tid      prio (all id:s are in hex)
00000008 (D) C:\Program Files (x86)\Origin\Origin.exe
	["C:\Program Files (x86)\Origin\Origin.exe"]
	0000003c    0
	00000009    0 <==
0000000e services.exe
	0000002a    0
	00000025    0
	0000001d    0
	00000015    0
	00000014    0
	00000013    0
	00000010    0
	0000000f    0
00000011 winedevice.exe
	00000018    0
	00000017    0
	00000016    0
	00000012    0
00000019 OriginWebHelperService.exe
	["C:\Program Files (x86)\Origin\OriginWebHelperService.exe"]
	00000038    0
	00000037    0
	00000032    0
	00000030    0
	00000024    0
	00000021    0
	00000020    0
	0000001f    0
	0000001e    0
	0000001c    2
	0000001b    2
	0000001a    0
00000022 plugplay.exe
	00000027    0
	00000026    0
	00000023    0
00000028 winedevice.exe
	0000002d    0
	0000002c    0
	0000002b    0
	00000029    0
0000002e explorer.exe
	00000035    0
	00000034    0
	00000033    0
	0000002f    0
System information:
    Wine build: wine-4.0 ( Staging Esync )
    Platform: i386 (WOW64)
    Version: Windows 7
    Host system: Linux
    Host version: 4.15.0-45-generic
Running /home/*****/.local/share/lutris/runners/wine/tkg-4.0-x86_64/bin/wine /mnt/MintData/Lutris/Games/battlefield-1/drive_c/Program Files (x86)/Origin/Origin.exe
@Mr_Pyro Is that the latest versions of wine-staging and lutris for Linux Mint ?
I have recently gone through issues with Wine/Lutris for Origin… but it’s all working now.
Update: Success after changing the wine version to 3.21 protonified
