[SOLVED] L1T 2 Port DP 1.4 KVM USB 3.0 Switching
I am fairly confident that the problem is with the KVM but I wonder if someone else has seen a similar issue - Port 2 of my 2 port KVM doesn’t carry the USB 3.0 signals. USB 2 devices plugged into the USB 3.0 ports on the KVM work for both PCs, and USB 3 devices work for the device plugged into Port 1, but no such luck on Port 2.
I have swapped the full bundle of cables (DP/USB-B) between port 1 and port 2 - this confirms the issue is not with the cables or the PCs. When port 2 has a Mac connected and port 1 a PC, the devices do not show up on the Mac but they do show up on the PC. When the same cables are reversed so that the Mac cables are plugged into port 1, the devices don’t show up on the PC and do show up on the Mac.
Anyone seen anything like this before?
Edit: solution
One time there was a tiny piece of packing paper in one of the usb ports preventing handshake at usb3 speeds but usb2 was fine.
Can you blow into port 2 and make sure it’s ok?
Otherwise I’d be happy to repair it.
I blew into the port and no change, though my diagnostics may have been flawed, as even plugging a basic keyboard into one of the USB 3.0 ports isn’t working for the port 2 PC - maybe I imagined that? Definitely still delivers power regardless of which PC is selected.
The HID USB are working as expected for both PCs.
I also unplugged everything and let it sit for a while, but I’m very open to any other diagnostics you think are worthwhile.
try pressing scroll scroll f7
there is a mode where usb3 ports can be left at a particular computer with a shortcut that uses scroll-scroll f7 you may have hit by accident.
That was it! I feel pretty silly for having almost immediately misplaced the manual - and I really appreciate the help.
Im still waiting on wendell to post soft copies on the forum/store/ somewhere.
