Solved...kind of: Supermicro H12SSL-i SATA Hotplug not working?
We just got a new server yesterday, however, I can’t get it to recognize SATA drives unless I reboot the system with either Proxmox 7.4 or 8.1 which is weird as it works fine with UnRAID.
The SATA configuration is on page 74 of the above manual and I have verified that SATA Enable is set to “Enabled” and SATA Hotplug is also set to “Enabled”.
Backplane manual:
I’ve opened a ticket with Supermicro, however, they’re not really being all that helpful and I’m wondering if anyone has any ideas?
EDIT (Solved…kind of):
If I run this command from the Proxmox shell then the drives are discovered if newly inserted or removed if I physically removed them.
Having the “Reload” button in the Disks screen work though would be ideal.
for arg in /sys/class/scsi_host/*/scan; do echo “- - -” > $arg; done
Same thing here with latest (as of writing) Proxmox 8.2.2
Got me really puzzled, because at first i thought my new 19" chassis has a problem with it’s drive bays.
Thanks for your tipp!
