[SOLVED] IOMMU passthrough vfio-pci
running:
grub2-mkconfig -o /etc/grub2-efi.cfg
returns message:
/etc/default/grub: line 6: rd.driver.pre=vfio-pci: command not found
but running:
modinfo vfio-pci
shows:
filename:       /lib/modules/4.18.8-200.fc28.x86_64/kernel/drivers/vfio/pci/vfio-pci.ko.xz
description:    VFIO PCI - User Level meta-driver
author:         Alex Williamson <[email protected]>
license:        GPL v2
version:        0.2
srcversion:     E46B6F702716FC27AA782E7
depends:        vfio,irqbypass,vfio_virqfd
retpoline:      Y
intree:         Y
vermagic:       4.18.8-200.fc28.x86_64 SMP mod_unload
sig_id:         PKCS#7
signer:
sig_key:
sig_hashalgo:   md4
signature:      30:82:02:CF:06:09:2A:86:48:86:F7:0D:01:07:02:A0:82:02:C0:30:
		82:02:BC:02:01:01:31:0D:30:0B:06:09:60:86:48:01:65:03:04:02:
		01:30:0B:06:09:2A:86:48:86:F7:0D:01:07:01:31:82:02:99:30:82:
		02:95:02:01:01:30:70:30:63:31:0F:30:0D:06:03:55:04:0A:0C:06:
		46:65:64:6F:72:61:31:22:30:20:06:03:55:04:03:0C:19:46:65:64:
		6F:72:61:20:6B:65:72:6E:65:6C:20:73:69:67:6E:69:6E:67:20:6B:
		65:79:31:2C:30:2A:06:09:2A:86:48:86:F7:0D:01:09:01:16:1D:6B:
		65:72:6E:65:6C:2D:74:65:61:6D:40:66:65:64:6F:72:61:70:72:6F:
		6A:65:63:74:2E:6F:72:67:02:09:00:C3:F4:C6:54:5E:B4:F8:0E:30:
		0B:06:09:60:86:48:01:65:03:04:02:01:30:0D:06:09:2A:86:48:86:
		F7:0D:01:01:01:05:00:04:82:02:00:5F:B4:85:8B:D8:52:DD:3C:0C:
		8C:1F:D8:A0:CD:32:2E:5E:B4:63:0D:D5:55:52:6E:62:FB:51:72:2F:
		E5:4E:8A:65:07:F3:C0:93:08:03:88:6E:43:A6:10:C1:B8:90:99:5D:
		17:53:B6:E6:23:53:5B:EF:66:D2:25:57:F3:15:AC:6C:C1:36:8D:B5:
		D8:24:0E:F4:3E:08:04:8B:FC:0C:FF:78:E5:C4:BC:A8:B8:03:37:1E:
		BD:A3:A9:4A:62:08:D7:D1:EC:87:7D:5B:96:8A:43:B9:61:89:89:D0:
		35:F3:95:8B:8E:47:22:64:9F:C9:C3:3F:87:B5:D2:1A:47:00:38:C7:
		03:29:56:CB:6B:82:B9:B8:CD:00:B3:4F:81:36:91:2F:9C:30:17:0E:
		C4:A6:9C:6B:69:8A:D9:09:92:46:2C:06:30:74:1A:B7:AF:AE:2E:C4:
		5C:B0:24:DD:2C:74:7B:4C:6F:A8:30:14:C0:A2:61:2A:4E:26:CE:97:
		3B:D2:C5:7A:EF:1D:AD:E1:B6:FE:A1:8F:56:95:26:02:24:5A:EB:65:
		24:DE:B9:D4:85:2C:80:3F:C6:9F:7F:0A:48:F6:B8:62:B0:FC:94:78:
		09:45:3C:DD:9D:15:54:D5:43:3B:2F:84:88:92:1E:C9:79:06:C4:1C:
		FA:87:F7:F1:43:B2:54:D8:CF:3A:35:D1:4F:F9:3A:1B:ED:07:DA:92:
		AD:81:91:F0:B8:BB:52:75:05:39:EE:D0:86:01:EC:D4:31:B5:0D:C3:
		2C:38:D5:4E:E0:D3:93:5A:09:16:41:25:A0:B5:49:FE:0A:39:BD:2D:
		EA:55:AC:18:CE:2A:09:4C:1D:79:8F:25:3E:08:3D:20:52:5E:B2:FD:
		CC:B1:51:73:B4:82:60:9B:2F:2C:D8:3A:A1:C1:EC:86:10:39:A7:44:
		3C:7F:72:0D:FA:F4:98:DE:1F:98:0D:8E:D9:BF:50:AD:86:BE:6C:C1:
		E9:50:40:62:51:7D:C4:84:E5:8A:E2:01:5B:B4:6E:DD:EF:E6:71:38:
		13:87:28:A4:10:27:BC:C7:47:B5:AB:48:7E:AF:80:57:97:0E:20:DB:
		5E:E0:93:46:02:52:B6:86:C9:DF:91:D0:CB:E2:8C:30:00:E4:51:DA:
		29:48:A0:77:F3:52:E4:13:04:56:3A:88:0E:18:1F:17:96:D5:78:F3:
		FE:D9:1E:5C:44:57:AA:C7:E1:F1:34:84:12:E6:B9:D2:CA:A7:96:6A:
		B5:E4:72:61:BB:B6:CC:DD:DB:93:34:CF:B8:87:60:0D:5E:8F:16:8B:
		23:1A:55:3B:D6:08:08:B6:26:4A:74:2E:ED:45:58:B3:C8:58:2C:D2:
		7B:B8:69
parm:           ids:Initial PCI IDs to add to the vfio driver, format is "vendor:device[:subvendor[:subdevice[:class[:class_mask]]]]" and multiple comma separated entries can be specified (string)
parm:           nointxmask:Disable support for PCI 2.3 style INTx masking.  If this resolves problems for specific devices, report lspci -vvvxxx to [email protected] so the device can be fixed automatically via the broken_intx_masking flag. (bool)
parm:           disable_vga:Disable VGA resource access through vfio-pci (bool)
parm:           disable_idle_d3:Disable using the PCI D3 low power state for idle, unused devices (bool)
any suggestions?
What distro you are running and the contents of /etc/default/grub would be useful.
If you are trying to load the vfio-pci module, it should be put in modules(file name/location depends on distro), then update your initramfs.
If you are trying to isolate a gpu with vfio-pci then use vfio-pci.ids=id in grub.
I’m using fedora 28, and basically went wendels fedora 26 recipe how to set it up, thats why I’m a little bit unsure whats going on, cause it seem pretty straight forward, searching on google didn’t give me any usefull results in the first 20 hits
cat /etc/default/grub
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
GRUB_DEFAULT=saved amd_iommu=on
GRUB_DISABLE_SUBMENU=false
GRUB_TERMINAL_OUTPUT="console"
GRUB_CMDLINE_LINUX="resume=UUID=012d9466-2d6a-452b-910d-e86cfc5ec564 rd.lvm.lv=fedora_localhost-live/root rd.lvm.lv=fedora_localhost-live/swap rhgb quiet rd.driver.blacklist=nouveau iommu=1 amd_iommu=on " rd.driver.pre=vfio-pci
GRUB_DISABLE_RECOVERY="true"
actually code highlighting shows it here wrong placement of ending "
:smiley: I better go into hiding right now. thanks for making me copy it, otherwise it would have taken me days to figure it out.
Glad to help, minor syntax errors are sometimes the worst to troubleshoot but the easiest to fix.
Also, don’t forget to mark as solved.
