So I installed a Mellanox 10G network card into my Proxmox Server. Its showing as being installed. I then swapped my bridge over to use the 10G nic. I can access it, and transfer files between machines, but still only at 115MB/s max.
Heres info I pulled so far…
# lspci -nn | grep Ethernet
01:00.0 Ethernet controller: Mellanox Technologies MT27500 Family [ConnectX-3]
# ip addr
4: enp1s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq master vmbr0 state UP group default qlen 1000
link/ether f4:52:14:55:5f:70 brd ff:ff:ff:ff:ff:ff
# cat /sys/class/net/enp1s0/speed
10000
If I am reading the output correctly, the Cat command shows its operating at 10G speed (10,000). However # ip addr shows it at 1,000?
I checked the switch side and the cisco router is showing a full 10G connection (I had fun searching how to take it out of “Stacking Mode” to stand alone to open up the 10G ports already lol). XG28 port below
Do I have to manually tell Debian/Proxmox to use 10,000 vs 1,000 speed? If so, where would I do this?
Any help appreciated.
115MB/s is about the speed of a HD.
Can you run an iperf on the link and verify that your storage is not what is slow?
Sure, its a RAID 10 array with 6 disks.
Any help with command format? I’m still learning…NM I got it need to install it… on both machines…lol
#iperf -s on the server
#iperf -c 198.51.100.5 -d from the client
Perfect, Its the guide I’m using. I have to reboot other machine.
[ ID] Interval Transfer Bandwidth
[ 3] 0.0-10.0 sec 2.57 GBytes 2.21 Gbits/sec
Seems its connected. My second machine is only connected at 2.5G… Guess thats as fast as my raid array is…humm
ZFS, MDADM, or hardware RAID?
ZFS raid 10, 7200rpm Ironwolfs 6 total. Samaba shares are still half speed between Linux clients so that will be next on the list.
I guess I was hoping for a little more oommpphhh… Guess SSD storage is needed lol.
The iperf command transfer between the server instance and the client instance.
It’s not tied to disk/array speed.
Any delay would be more likely network config.
Technically it could be bottlenecked by ram or cpu, but you are unlikely to be testing it on a machine with faster network than processor/ram…
Yeah its the ryzen 7 2700 64GB asrockrack server I built and a ryzen 3700x 32GB machine.
Does it do 10 tests, and give an average? (Median/mean/highest?)
No that was the only output I got.
Linux? I get a bunch of tests, but seems I have iperf3
(And yes, I Did have to read the manual…)
This is between 2 proxmox servers with 10gb nics in them.
[ 3] 0.0-10.0 sec 10.9 GBytes 9.35 Gbits/sec
(which seems plausible)
Yeah my iperf says it has 2.3Gbytes a sec so that’s close to the max of my second machine with a 2.5G nic. I am waiting to install the second nic in the other server. I may have to try iperf3 instead regular to get all those tests. So it seems the connection is there and working right, so must be a disk max speed issue.
its your disks, 99% sure. I am doing a few test benches on 6x SAS SSD’s and while I am no ZFS expert so these are not tuned the results are telling.
config:
NAME STATE READ WRITE CKSUM
raid10 ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
sda ONLINE 0 0 0
sdb ONLINE 0 0 0
sdc ONLINE 0 0 0
mirror-1 ONLINE 0 0 0
sdd ONLINE 0 0 0
sde ONLINE 0 0 0
sdf ONLINE 0 0 0
RANDREAD: bw=81.7MiB/s (85.7MB/s)
RANDWRITE: bw=15.1MiB/s (15.9MB/s)
SEQWRITE: bw=84.9MiB/s (89.1MB/s)
SEQREAD: bw=218MiB/s (229MB/s)
NAME SIZE ALLOC FREE CKPOINT EXPANDSZ FRAG CAP DEDUP HEALTH ALTROOT
raid10 7.00T 4.00G 6.99T - - 0% 0% 1.00x ONLINE -
config:
raid10 ONLINE 0 0 0
sda ONLINE 0 0 0
sdb ONLINE 0 0 0
sdc ONLINE 0 0 0
sdd ONLINE 0 0 0
mirror-2 ONLINE 0 0 0
sde ONLINE 0 0 0
sdf ONLINE 0 0 0
RANDWRITE: bw=24.3MiB/s (25.4MB/s)
RANDREAD: bw=94.4MiB/s (99.0MB/s)
SEQWRITE: bw=121MiB/s (127MB/s)
SEQREAD: bw=221MiB/s (232MB/s)
Yeah I was fairly sure. Thank you though, good tool to have in the tool box. Iperf that is.
If I transfer a 1gb file between these servers - i get…
100% 975MB 330.8MB/s 00:02
(using scp) This is most likely drive limitations…
sam
What category of cable are you using and what’s the run length?
