So recently, I went out and got a Noctua NH-U14S CPU cooler, The reason for this was because i thought my CPU fan died and i wanted a better cooler anyways, So i bought one. Installed it, Turned Charlotte on, And it does not spin... Ok.. So i plugged it into the CPU_OPT Input, Still Nothing, And i have the Red Light on for the CPU, Meaning Something is wrong, BUT WHAT?!?!
I am using the M5A99FX Pro R2.0 Motherboard with an AMD - FX - 8350 CPU and no, The CPU light just stays lit and nothing comes on the screen, CPU fan does NOT spin
ALL of the other fans spin, Just not the CPU Fan, This is why i replaced my Stock Cooler, Because the CPU died, MEaning it stopped spinning so the computer would not load past post, So i got a new cooler thinking it was the cooler... Seems it might be something more severe...
Alright i will do so right now, But if i am not mistaking, The CPU will not go past Post if there is not soemthing plugged into the CPU Fan Plug, But i will try anyways, i am begginign to get desperate.
Did you do any overclocking? Something somewhere may have burned itself, most likely your cpu since you had the stock cooler. Try doing a post without the ram, like has already been mentioned before. This is going to narrow down the problem to just the cpu and mobo. If you can get into bios by now, reset any changes that you have made, or just clear cmos.
And no i did NO over clocking, The MAX temp on the CPU was 64C and the max safe temp is 90C
So it's possible that the CPU burned out, But that still does not explain why the fan is not spinning either of the 5 Fan Headers, Im really beginning to think this is a Motherboard issue, But i am very much willing to try anything to confirm this 100%
Right now as you read this message i am removing the RAM.
