There seem to be 3 versions of those.
One without anything, just Wii to HDMI
Wii to HDMI and 3.5mm jack with button
Wii to HDMI and 3.5mm jack without button (the one you linked).
I think I will just order one of those and see how it goes.
If it was just that easy, I would have just ordered the same thing again, but it is never that easy.
Depends what the second one does since we don’t see the output? Is that analogue as well? If yes then I don’t see the point. If it’s HDMI then I can understand the price, and quality makes a massive difference for SCART -> HDMI.
Doesn’t really matter whether it’s Composite to SCART to HDMI, what counts are really the internal components, but hard to say for pretty much noname products…
Ordered this, package arrived, plugged it in, set it to 720p 50Hz and it works. Audio via HDMI is there, picture quality is as good as it gets for 480i upscaled.
Case closed.
