(solved) Best GPU for an I5k build
http://pcpartpicker.com/p/2Doaw
and any other upgrade suggestions?
What's the budget?
4 titans
Just guessing, but maybe the 770/280x range? of course if you have the budget a 780 would work, the 290's are a little (ok, a lot) inflated due to bitcoin mining.
And a custom water loop
no real budget my mobo will only take 2 way sli or crossfire
im considering a custom liquid loop but i will have to switch to a more water cooling friendly case
Based in your monitor, 1080p @ 60 hz, you really only need around a 280x/7950 or a 680/770 to max all of the games. So just go with the cheapest of the four, really.
cool thank you :D
ya with gpu prices being high right now look around for one of those four.  The gtx 670 and 7970 you can also add to your list to look for.
i did some looking and (ASUS DirectCU II GTX770-DC2OC-4GD5 GeForce GTX 770 4GB 256-Bit GDDR5 PCI Express 3.0 HDCP Ready SLI Support Video Card) this is just as much as a 670 and 7970 will the extra 2 gb help me at all? or just be overkill
Unless you play at 1440p, 4gbs is usless
 it is tempting though
GTX 670 matches the 760 very closely, so don't get that. GTX 770 is your best bet right now. 4 GB is fine if you plan on gaming with intense mods and if you can afford it, it may be good enough. You can get a 780 if you feel like future proofing your system a bit for 1080p.
i think ill go with a 770 newer part for equal money lol thank you for your opinions
Great then i put a lock on this.
Have fun.
Grtz Angel ☺
