When I play games using LG, I have more than 2x less fps. I have disabled gsync and vsync. I tried with and without spice but nothing change.
Also sometimes, my LG freezes and I can’t kill the process on the windows host, I have to reboot to VM.
I have nothing in logs for both problems.
High chance I did something bad but I don’t really know where to look.
Host GPU: 5700xt
Client GPU: 4070
CPU: 5600x
OS: Arch/W11
LG: B6
Screen: 1920x1080 144hz
My current VM XML:
<domain type="kvm">
<name>win11</name>
<uuid>f7b469f1-b897-4968-9482-440a90c30d86</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/11"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">33554432</memory>
<currentMemory unit="KiB">33554432</currentMemory>
<memoryBacking>
<hugepages/>
</memoryBacking>
<vcpu placement="static">8</vcpu>
<iothreads>1</iothreads>
<cputune>
<vcpupin vcpu="0" cpuset="2"/>
<vcpupin vcpu="1" cpuset="8"/>
<vcpupin vcpu="2" cpuset="3"/>
<vcpupin vcpu="3" cpuset="9"/>
<vcpupin vcpu="4" cpuset="4"/>
<vcpupin vcpu="5" cpuset="10"/>
<vcpupin vcpu="6" cpuset="5"/>
<vcpupin vcpu="7" cpuset="11"/>
<emulatorpin cpuset="0-1,6-7"/>
<iothreadpin iothread="1" cpuset="0-1,6-7"/>
</cputune>
<os firmware="efi">
<type arch="x86_64" machine="pc-q35-8.0">hvm</type>
<firmware>
<feature enabled="no" name="enrolled-keys"/>
<feature enabled="yes" name="secure-boot"/>
</firmware>
<loader readonly="yes" secure="yes" type="pflash">/usr/share/edk2/x64/OVMF_CODE.secboot.fd</loader>
<nvram template="/usr/share/edk2/x64/OVMF_VARS.fd">/var/lib/libvirt/qemu/nvram/win11_VARS.fd</nvram>
</os>
<features>
<acpi/>
<apic/>
<hyperv mode="custom">
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
<vpindex state="on"/>
<synic state="on"/>
<stimer state="on"/>
<reset state="on"/>
<vendor_id state="on" value="kvm hyperv"/>
<frequencies state="on"/>
</hyperv>
<kvm>
<hidden state="on"/>
</kvm>
<vmport state="off"/>
<smm state="on"/>
<ioapic driver="kvm"/>
</features>
<cpu mode="host-passthrough" check="none" migratable="on">
<topology sockets="1" dies="1" cores="4" threads="2"/>
<cache mode="passthrough"/>
<feature policy="require" name="topoext"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x9"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0xa"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0xb"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0xc"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0xd"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x5"/>
</controller>
<controller type="pci" index="7" model="pcie-root-port">
<target chassis="7" port="0xe"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x6"/>
</controller>
<controller type="pci" index="8" model="pcie-root-port">
<target chassis="8" port="0xf"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x7"/>
</controller>
<controller type="pci" index="9" model="pcie-root-port">
<target chassis="9" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="10" model="pcie-root-port">
<target chassis="10" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="11" model="pcie-root-port">
<target chassis="11" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="12" model="pcie-root-port">
<target chassis="12" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="13" model="pcie-root-port">
<target chassis="13" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="14" model="pcie-root-port">
<target chassis="14" port="0x15"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x5"/>
</controller>
<controller type="pci" index="15" model="pcie-root-port">
<target chassis="15" port="0x16"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x6"/>
</controller>
<controller type="pci" index="16" model="pcie-to-pci-bridge">
<model name="pcie-pci-bridge"/>
<address type="pci" domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<interface type="network">
<mac address="52:54:00:0d:34:f8"/>
<source network="enp42s0"/>
<model type="virtio"/>
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</interface>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<input type="mouse" bus="virtio">
<address type="pci" domain="0x0000" bus="0x08" slot="0x00" function="0x0"/>
</input>
<input type="keyboard" bus="virtio">
<address type="pci" domain="0x0000" bus="0x09" slot="0x00" function="0x0"/>
</input>
<input type="evdev">
<source dev="/dev/input/by-id/usb-Logitech_USB_Receiver-if02-event-mouse"/>
</input>
<source dev="/dev/input/by-id/usb-Keychron_Keychron_K3_Pro-event-kbd" grab="all" grabToggle="ctrl-ctrl" repeat="on"/>
</input>
<tpm model="tpm-tis">
<backend type="emulator" version="2.0"/>
</tpm>
<audio id="1" type="none"/>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x01" slot="0x00" function="0x0"/>
</source>
<boot order="1"/>
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x2b" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x2b" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</hostdev>
<watchdog model="itco" action="reset"/>
<memballoon model="none"/>
<shmem name="looking-glass">
<model type="ivshmem-plain"/>
<size unit="M">32</size>
<address type="pci" domain="0x0000" bus="0x10" slot="0x01" function="0x0"/>
</shmem>
</devices>
</domain>
LG client (my linux)
❯ looking-glass-client -s -F
[I] 4669462403 main.c:1785 | main | Looking Glass (B6)
[I] 4669462418 main.c:1786 | main | Locking Method: Atomic
[I] 4669462601 cpuinfo.c:37 | lgDebugCPU | CPU Model: AMD Ryzen 5 5600X 6-Core Processor
[I] 4669462609 cpuinfo.c:38 | lgDebugCPU | CPU: 1 sockets, 6 cores, 12 threads
[I] 4669469000 main.c:1162 | lg_run | Using font: /usr/share/fonts/TTF/DejaVuSansMono.ttf
[I] 4669469055 ivshmem.c:128 | ivshmemOpenDev | KVMFR Device : /dev/shm/looking-glass
[I] 4669469089 egl.c:267 | egl_initialize | Double buffering is off
[I] 4669469094 main.c:1116 | tryRenderer | Using Renderer: EGL
[I] 4669477282 gl.c:58 | waylandGetEGLDisplay | Using eglGetPlatformDisplay
[I] 4669498724 egl.c:828 | egl_renderStartup | Single buffer mode
[I] 4669500210 egl.c:855 | egl_renderStartup | EGL : 1.5
[I] 4669500215 egl.c:856 | egl_renderStartup | Vendor : AMD
[I] 4669500218 egl.c:857 | egl_renderStartup | Renderer: AMD Radeon RX 5700 XT (navi10, LLVM 15.0.7, DRM 3.49, 6.1.46-1-lts)
[I] 4669500221 egl.c:858 | egl_renderStartup | Version : OpenGL ES 3.2 Mesa 23.1.6
[I] 4669500225 egl.c:859 | egl_renderStartup | EGL APIs: OpenGL OpenGL_ES
[I] 4669500231 egl.c:930 | egl_renderStartup | Debug messages disabled, enable with egl:debug=true
[I] 4669529086 eglutil.c:35 | swapWithDamageInit | Using EGL_KHR_swap_buffers_with_damage
[I] 4669532896 main.c:1566 | lg_run | Guest Information:
[I] 4669532901 main.c:1567 | lg_run | Version : B6
[I] 4669532903 main.c:1588 | lg_run | UUID : f7b469f1-b897-4968-9482-440a90c30d86
[I] 4669532909 main.c:1597 | lg_run | CPU Model: AMD Ryzen 5 5600X 6-Core Processor
[I] 4669532914 main.c:1598 | lg_run | CPU : 1 sockets, 4 cores, 8 threads
[I] 4669532915 main.c:1600 | lg_run | Using : DXGI Direct3D 11
[I] 4669532917 main.c:1636 | lg_run | OS : Windows
[I] 4669532919 main.c:1638 | lg_run | OS Name : Windows 10 Pro (Build: 22621)
[I] 4669532920 main.c:1660 | lg_run | Starting sessio[I] 4669675358 main.c:698 | main_frameThread | Format: FRAME_TYPE_BGRA 1920x1080 stride:1920 pitch:7680 rotation:0
LG host (Windows)
[I] 183621300 dxgi.c:390 | dxgi_init | Device Name : \\.\DISPLAY1
[I] 183621841 dxgi.c:391 | dxgi_init | Device Description: NVIDIA GeForce RTX 4070
[I] 183622364 dxgi.c:392 | dxgi_init | Device Vendor ID : 0x10de
[I] 183622855 dxgi.c:393 | dxgi_init | Device Device ID : 0x2786
[I] 183623383 dxgi.c:394 | dxgi_init | Device Video Mem : 12026 MiB
[I] 183623903 dxgi.c:395 | dxgi_init | Device Sys Mem : 0 MiB
[I] 183624390 dxgi.c:396 | dxgi_init | Shared Sys Mem : 16374 MiB
[I] 183679129 dxgi.c:503 | dxgi_init | Feature Level : 0xc100
[I] 183679548 dxgi.c:504 | dxgi_init | Capture Size : 1920 x 1080
[I] 183679897 dxgi.c:505 | dxgi_init | AcquireLock : enabled
[I] 183680172 dxgi.c:506 | dxgi_init | Debug mode : disabled
[I] 183682639 dxgi.c:598 | dxgi_init | Source Format : DXGI_FORMAT_B8G8R8A8_UNORM
[I] 183682970 dxgi.c:640 | dxgi_init | Request Size : 1920 x 1080
[I] 183684413 dxgi.c:658 | dxgi_init | Output Size : 1920 x 1080
[I] 183684777 dxgi.c:666 | dxgi_init | Copy backend : Direct3D 11
[I] 183685061 dxgi.c:667 | dxgi_init | Damage-aware copy : enabled
[I] 183685533 app.c:379 | captureStart | ==== [ Capture Start ] ====
[I] 183685865 app.c:312 | frameThread | Frame thread started
