Hey all,
I have spent the afternoon updating and trying to find the 4G decoding setting to enable my system to boot with a Tesla M40 installed.
running the latest bios version.
I saw that this setting was available on the TahiChi board but does not appear to be on the pro gaming board. If anyone has any ideas they would be much appreciated.
See here
If not giga can probably help just @ him here if that doesnt help
I saw that post and that was what prompted me to look into 4G decoding.
The issue is that I can not see the setting listed in the bios to enable it.
Bios just updated to v3.8
its under the enterprise name
go here
Ctrl+F
SEV-ES ASID Space Limit
you’ll have to do some googling to fine tune the specifics
you’ll also need to be running GPT on your storage and something about CSM I forget, its in the other threads
Legend!! I will try after work tomorrow and report back
Cheers
Thank you for all your help @GigaBusterEXE
Got the card working!
After disabling CSM in the UEFI the option to enable 4g decoding appears and the system booted right up after that
Once again thank you so much for the headache you saved!
