[Solved] Asrock wrx80 creator R 2.0 - D1 Ram Issue
Hello!
I am currently experiencing issues with the D1 RAM slot in a 8 memory sticks configuration.
System Specs:
  • AMD Threadripper Pro 5995WX
  • ASRock WRX80 Creator R2.0
  • 8x Samsung 32GB 3200MHz ECC Module (M393A4K40DB3-CWE)
While it initially booted fine showing all 8 banks occupied, both in Bios and Windows 10, for the full 256GB, after a reboot it started to show that D1 did not have a memory stick, both in bios and windows. I changed the memory modules between themselves and it temporarily fixed the problem, until I reboot again the machine.
Does anyone have some insights on how to fix this issue?
(I already contacted Asrock tech support, but it may take a while).
Best,
Rolando
Other than reseating he cpu, and checking the ram slot to ensure there isn’t any issue, I don’t think there is much you can do.
Thanks for the reply.
I managed to solve my issue.
Actually asrock support was good, and provided some guidelines to troubleshoot the problem.
Beside reseating the cpu, I lowered the torque applied to both the socket and waterblock.
Additional I repositioned one motherboard support pin that was left there from my previous trx40 board. Because I did all this at once I cannot 100% say what fixed it, but I would guess it was the pin shorting the MB.
At least it’s fixed now!
With this motherboard make sure to remove the top middle standoff/motherboard support that is right below the D1 memory slot.
Thank you all for this thread. I was troubleshooting someone’s workstation and the cooler was over-torqued. Loosening the cooler mount gave me back D1.
