Hi level1,
we are trying to setup a 40gbit connection between two servers and get weird cpu behaviour when using iperf. It is also only using around 10Gbit/s of the possible 40.
Server specs:
AMD EPYC 7413
8x MultiBitECC 3200 MHz 16384 MB Memory
Supermicro H12SSL-CT
Intel XL710 40GBe
Ubuntu 20.04.3 LTS 5.4.0-84-gene
The Servers are connected directly to each other via fibre. No switches.
Example
host1# iperf -s
host2# iperf -c host1 -i 1 -t 120
[ ID] Interval Transfer Bandwidth
[ 3] 0.0- 1.0 sec 1.39 GBytes 12.0 Gbits/sec
[ 3] 1.0- 2.0 sec 1.00 GBytes 8.61 Gbits/sec
[ 3] 2.0- 3.0 sec 1.03 GBytes 8.88 Gbits/sec
[ 3] 3.0- 4.0 sec 1.04 GBytes 8.92 Gbits/sec
[ 3] 4.0- 5.0 sec 1021 MBytes 8.56 Gbits/sec
[ 3] 5.0- 6.0 sec 1.05 GBytes 9.01 Gbits/sec
[ 3] 6.0- 7.0 sec 1.02 GBytes 8.78 Gbits/sec
[ 3] 7.0- 8.0 sec 1.02 GBytes 8.74 Gbits/sec
[ 3] 8.0- 9.0 sec 1.01 GBytes 8.69 Gbits/sec
[ 3] 9.0-10.0 sec 1.02 GBytes 8.75 Gbits/sec
[ 3] 10.0-11.0 sec 1.05 GBytes 9.03 Gbits/sec
[ 3] 11.0-12.0 sec 1015 MBytes 8.51 Gbits/sec
[ 3] 12.0-13.0 sec 1.02 GBytes 8.72 Gbits/sec
[ 3] 13.0-14.0 sec 1014 MBytes 8.51 Gbits/sec
[ 3] 14.0-15.0 sec 974 MBytes 8.17 Gbits/sec
[ 3] 0.0-15.0 sec 15.6 GBytes 8.92 Gbits/sec
Any suggestion to why either iperf send the CPU sleeping or how I could improve single thread tcp transmission speed? Running multiple tcp threads utilizes the bandwidth better but is not our use case.
thank you
btw. I asked the questen on server fault too and was suggested to ask here.
EDIT:
here are some example readings
without iperf running
cpupower -c 0-47 monitor
| Mperf || Idle_Stats
CPU| C0 | Cx | Freq || POLL | C1 | C2
0| 6,16| 93,84| 2822|| 0,00| 3,61| 90,27
24| 0,01| 99,99| 1532|| 0,00| 0,00|100,00
1| 0,04| 99,96| 1982|| 0,00| 0,00| 99,97
25| 0,04| 99,96| 1502|| 0,00| 0,00| 99,96
2| 0,00|100,00| 1498|| 0,00| 0,00| 100,0
26| 0,00|100,00| 1127|| 0,00| 0,00|100,00
3| 0,00|100,00| 1614|| 0,00| 0,00| 100,0
27| 0,00|100,00| 1567|| 0,00| 0,00|100,00
with iperf running
| Mperf || Idle_Stats
0| 2,88| 97,12| 413|| 0,00| 0,17| 96,82
24| 12,30| 87,70| 416|| 0,00| 0,49| 87,13
1| 0,42| 99,58| 412|| 0,00| 4,21| 95,39
25| 5,50| 94,50| 420|| 0,00| 0,38| 94,09
2| 0,08| 99,92| 407|| 0,00| 0,00| 99,92
26| 12,54| 87,46| 463|| 0,00| 0,65| 86,73
3| 0,02| 99,98| 408|| 0,00| 0,00| 99,98
27| 15,66| 84,34| 440|| 0,00| 0,00| 84,27
