[SOLVED] 8 pin connector, what cable do you connect it with?
Hello. As the title states. I’m looking at motherboard to get and it has 8 pin connector on it and I’m not sure what cable do you connect it with. My current mobo has 4 pin one and the psu has 2 of those. Do you just combine them together for the 8 pin slot?
That’s the one I’m talking about.
cpu only uses 1x of the 4 pins
should state on the cable cpu for modern psu’s. also the gpu cable is similar
I can share the picture of the motherboard to give context.
Here.
If before you used just one of those 4 pins then on the new motherboard you combine them both to get the 8pin plug.
If its incorrect it will not fit, so do not force it.
Oh, thanks. I wanted to be extremely secure before I try anything like that.
motherboard has always been > if the cable doesnt fit, it doesn’t go there… and read the manual
