Solidigm) Intel P4510 U.2 SSD: Power Usage and Power Management. Help?
Ref: Solidigm Storage Tool 3.x Manual
Bash:
# lspci -nnk -s 03:00
03:00.0 Non-Volatile memory controller [0108]: Intel Corporation NVMe Datacenter SSD [3DNAND, Beta Rock Controller] [8086:0a54]
        Subsystem: Intel Corporation NVMe Datacenter SSD [3DNAND] SE 2.5" U.2 (P4510) [8086:4802]
        Kernel driver in use: nvme
        Kernel modules: nvme
Hello,
I could use a bit of advice on how to use the P4510 and what to expect from it. This is my first U.2 disk, and I’ve quickly realized it’s not just an m.2 NVME in a different form factor. I’ve got a few questions:
  1. Is there a way to get it to report what it’s actually drawing?
  2. If you’re able to isolate its power draw, what are y’all seeing?
  3. Have you experimented with altering the power management profile?
I have my P4510 in a Proxmox server. It’s currently unformatted and unmounted. All I’ve done is use an adapter to plug it into an m.2 NVME slot.
It appears to be idling at about 20w.
I know U.2s take more power than m.2 NVME, but I was really surprised to see that–especially since without the U.2, the entire system idles at about 65w. It was startling to see my idle power jump to 85w.
However, the datasheet seems to suggest that’s in the normal range for this series of SSDs. Bummer.
Part of me wonders if it might use less power once it’s formatted and mounted (e.g., once the system has more active control of it and can put it into a lower power state). I’d like to pass it through to a Bazzite VM to use for game storage, but I won’t be using that VM all the time. If it’s going to behave better when it’s actually formatted and mounted, it might make more sense to blacklist the device so Proxmox can’t see it at all and it only gets turned on inside the VM.
That doesn’t seem like the correct solution, though.
I noticed this in the SST 3 manual:
Power Governor Mode (vendor unique). Three modes are supported:
• 0: 25-watts for PCIe NVMe devices; 40W for PCIe NVMe x8 devices; Unconstrained for SATA devices.
• 1: 20-watts for PCIe NVMe devices; 35W for PCIe NVMe x8 devices; Typical (7-watts) for SATA devices.
• 2: 10-watts for PCIe NVMe devices; 25W for PCIe NVMe x8 devices; Low (5-watts) for SATA devices.
That’s definitely got me curious. I’m sure that the lower power modes would have a performance tradeoff, but adding at least 20w to my idle power draw is not ideal. I’m curious if lowering the power just lowers the maximum speed, or reduces I/O in general. If it’s the former, that might not be so terrible. This drive will mostly be used for reads, and in this system I’m seeing ~3.0 GB/s reads right now. Dropping that down even to SATA III speeds to save power wouldn’t be terrible.
And after some poking around,
Bash:
root@andromeda1:~/utilityScripts/intel/intel-solidigm/sst-3.0# sst show --ssd /dev/nvme0n1 --getfeature PowerManagement
- PHLJ828500C64P0DGN -
DWORD0 : 0x0
NVMePowerState : 0
Well, that explains the massive power usage, at least. It’s in guzzle mode.
So, I guess the real question is: how does putting it in mode 2 impact drive performance? What am I giving up if I only give it 10w to work with?
the 4510 is the old gen. P5620 series do idle at 5w. But at same time, what do you care about the power ? if the electricity is too high, just skipping those 10$ coffee and it’s all paid. u2 is not meant to be used in laptop anyway.
