i was in facebook when suddenly my pc turned off. i turn it on again black screen with message saying to load media disk.
i checked the wires,chsnged them, power good.
gave up and try to repair with windows cd no good. message; said the my windows was currently lucked and i need it to unluck it.
check to reinstall windows, the only two partition i found was my 2 assistant harddrive.
conclusion; my Kingston HyperX 3K 120 GB SATA III 2.5-Inch 6.0 Gb/s is broken.
if it helps: MSI Z77A-GD65 Z77 DDR3 1600 LGA 1155 Motherboards
i build this pc ike 5 months ago and have been using it for gaming and stuff..
