Software Defined Radio - Analyzing help
Greetings,
I have a peculiar issue all around me, literally. I don’t want to spill all the beans but I believe the issue derives from GITHUB.
Over the past 4 months, my brain has been receiving a signal. As strange as that sounds I did a lot of testing to see if I was going insane, I don’t believe I am. How did the signal originate ? Filling in my tooth, seemed to trigger it or something done to my teeth for some kind of one and one millionth chance latched onto “the signal”.
What kind of signal, well transmission from a source into the auditory cortex. No one else can hear what I’m hearing, someone just said “good”, as they are watching my monitor, how clearly I have no idea. Clear enough to see me game and do AI art.
The extension of this is, it’s not just the monitor, they can see me at any position of the house, even the basement. There is only a handful of things that can do this. Let me also say I have a half faraday cage up , which doesn’t seem to block anything. I wrapped the HDMI cables in faraday as well. I first tried mylar thinking it was heat which I still believe it is but in terms of how I can’t fully understand.
What could it be, I beleive its a combination of items such as a Deplife system or the likes, Tempest SDR with a signal booster and some kind of FLIR imaging. Another apsect, turned my computer all the way off, and I could still hear them, opening my window I heard drone propellors. SO signal boosting with a drone is another apsect of this. Using a drone for people who don’t have the type of microwave radiation around the, like HDMI, ect.
I’ve been viewed naked, through a partial faraday, mylar and foam panels by a “group” of residents here, I know exactly who they are and the police will do nothing. They’ve had viewing parties for which I crashed last night with my Satanic voice, softly through simple sound proofing, the cars flew out of the neighbors driveway. If they viewed me, they viewed other residents.
Right now I have a SRD usb dongle coming and I was hoping someone would know what frequency the Tempst SDR is running on. If I can record the frequency of transmission I maybe able to get their voices through it.
They think they are smart people, I don’t think they are. Even now when they think their soft whisper goes undected, its straight to the brain. Right now, the silence from my words on this forum is deafening.
So if anyone has any information on SDR technology , what to look for outside of homes, and maybe a simplier way at stopping the evasion of privacy I’d love to read them. Again information on Tempest SDR or like software , all ears (ahah :|).
I work in SDR.
I believe the correct tool to solve your problems is called a Psychotherapist.
99.9% chance it’s auditory hallucinations.
You can immediately rule out anything and everything that originates with a digital signal because these would all need to be decoded in order to be intelligible.
Only analog audio transmissions can plausibly be inadvertently received and even then, only signals that are amplitude modulated would be recognizable because chunks of metal don’t accidentally form FM receivers.
If anything you’d be looking for an AM audio signal source… but that’s only in the case that an external signal source even exists rather than the more likely explanation that it’s a hallucination.
Are your carbon monoxide detectors working correctly?
What you are experiencing sounds like Auditory Hallucinations.
There is a phenomena called the Taos Hum, it is a low frequency rumbling or droning sound, kind of industrial sounding. I have read 2% and up to 10% of the population has experienced it, but it is not what you are describing.
I’m under surveillance. A network of people have implanted devices who are working outside the government through the Granted company Deplife as they are testing a new implant that is inserted into the teeth and ear. For 4 months I was hearing audio of human voices as they watched my every move, this is going to be implanted into the armed forces but I believe people around the country may be having the same issue. They also use a satellite for live motion tracking.
This has broken my mind.
The device is implanted to capture single mental image for analysis through the optical radiations, as well as audio capture from a mental thought or mumble through the trigeminal nerve (imo) . The “soldier” can also hear sound through the the eardrum form some type of device that for me was inserted with an airsoft gun at range.
Mass testing over the last 2 weeks I’ve ID most of the voices of every person involved and working for them, as well as “clinical centers”
Flushing the ears is weakening the auditable signle.
The ears where done at a “clinic” for a “routine” ear exam. They used an “air pressure” test that most likely implanted two devices one per ear.
Intense paranoia accompanied by auditory hallucinations is text book schizophrenia.
I hope !
They diagnose based on criteria that you seem to pretty closely align with and schizophrenia is actually quite common with around 1 in 100 experiencing it at some point. If you can get an appointment for evaluation it’ll likely be a relatively quick diagnosis accompanied by a prescription for an antipsychotic. While antipsychotics are generally not a cure they do tend to be fairly effective at managing symptoms.
Proactively making some dramatic changes to your diet will also likely be helpful long term as the condition often correlates with metabolic disorder.
We’re straying pretty far off topic for a tech forum though. Best of luck.
6 volt to the ear tunnel made a few clicking osunds, the device oisnt complete shorted but signal extremely weakend. Ordered a an ear cleaning kit with a camera…
I was put under an legal / illegal surveillance. The items they used was my glasses and also an FMRI chip inside of my tooth. Theis allowed for the Realtime of translation of thoughts and memory flashes through my mind and eyes.
THe Fmri was then sent out transmitting images through various apps across my neighborhood. Regardless of the why, they legality of no nonconsenting implamation of such objects is to litigated. This was also added with a spatial surround sound in the ear through a micro device attached to my eardrum.
I apologize for wasting this forums time.
Quick update :
All surveillance items are in body.
Real time sight.
Real time hearing
Real time FMIR imagery
Real time Nerve analysis
Real time circulatory Analysis
For them too get the best usage they need 4 of the Dentsply Sorana made microchips.
I googled the Patent for such device : 2009 Microchips for Orthodontics with Sorana applying for usage in 2013.
My tooth is pulled and a dark square is incased inside of the filling. This is 100% real.
I have a Dr. up the road who been running the “program” with other resident’s on the road. My neighbor also set up remote recieving devices for direct radio signaling around the neighborhood.
On top of this, I may have had Edward Snowden hack into the chips and asked “hosw are they doing this”. That itself is the realization that remote satelitte hacks can take place from anywhere around.
I may be the first officially cyber-hacked brain in the world.
You need to see a Psychiatrist.. Go talk to someone at a mental health Urgent Care or ER, quickly.
