So Strix Halo is cool huh? Should I buy it or build my own system for gaming/general use?
INTRO
One of the questions we’ve seen on the forum a few times is if it’s a good idea to pick up a Strix Halo system like the Framework Desktop or one of the GMKTek mini PCs we’ve looked at recently fpr workloads other than AI. While the Ryzen AI Max 395+ that powers systems like these is an incredibly capable APU that can game at similar settings to the 4060M, it’s really meant for AI workloads first and foremost. So Wendell and I thought it might be a good idea to look at some SFF systems you can build for a similar price point that will perform better than Strix Halo in non AI workloads. Let’s take a look!
THE NO HOLDS BARRED SYSTEM
First up, what if you were willing to spend slightly more than the $2000ish that a top end Strix Halo system costs?
CASE
For our case, we’ve gone with the Cooler Master NR200P Max, which includes a PSU and cooler, which will significantly cut down our costs. For other cases, the Fractal Era or Fractal Terra are also excellent, designer choices.
CPU
Our CPU will be the Ryzen 9 9950X3D, because if you’re gonna go big, go big.
GPU
As far as gaming goes, it’s hard to find a better bang for your buck than the 9070XT. If you can find a 5080 for close to MSRP it would probably be good too, but the 9070XT is probably a better value.
MEMORY
For memory, we’re going with 128gb of DDR5. We won’t be able to touch Strix Halo in terms of memory bandwidth but we can get up there in terms of capacity.
STORAGE
I’ve picked a 2tb Samsung 990 for this build, but any 2tb NVMe SSD will do just fine. That gives us plenty of space to work with.
GRAND TOTAL
All of this stuff comes to around $2300, slightly more than most Strix Halo systems, but much more capable when it comes to non-AI workloads. You can play most any game on this on high settings at 1440p, with a good frame rate, and it’s only slightly bigger than something like the Framework Desktop. But what if you’re a little more cost conscious?
THE SENSIBLE SYSTEM
Not everyone can go all out when it comes to putting together a PC, but there are still some great options for the more price conscious among us.
CASE
We’re still gonna use a Cooler Master NR200P, but we’re going to go with the standard no-frills version here. Still a great case, we’ll just have to provide our own PSU.
“But wait, what about the cooler that comes with the NR200P Max? Won’t you still need a cooler?”
Funny you say that, random person I just made up. We won’t really need a cooler, just a fan. Why? Because our motherboard is going to be…
MOTHERBOARD/CPU/COOLER
The Minisforum BD790i X3D! This little guy packs both a built in 3D Vcache processor AND a built in heatsink, all you need to add is a fan. It’s not quite as strong as the 9950X3D, but it’s definitely no slouch for a mobile part, and will get you most of the way there.
GPU
The 9070XT would still be a decent choice here since it’s such a good bang for the buck, but we’re going to step down to a 9060XT, which is still a great card. If you can find a good deal on a 7900XTX, that would also be an excellent choice.
MEMORY
The Minisforum motherboard takes SODIMM memory, and we’re going to go with 64gb to offset the higher price of SODIMMs. If you need 128, feel free to go for it, but we think 64gb is sufficient for most things.
STORAGE
Any NVMe storage will work fine here, but we’re going to go with a 1tb Samsung 990 Pro. Again, feel free to choose whatever you want!
GRAND TOTAL
This system comes in at a much cheaper $1250ish and will still perform very very well, better than Strix Halo at most things. It might not be as good at AI but it’s a respectable platform for gaming and other workloads, and it CAN do AI stuff, it’ll just be slower.
So, as you can see, Strix Halo is fantastic, but you’re paying a lot for the AI performance and the unified memory, and most things don’t take advantage of that the way you would want them to. Still, if Strix Halo fits your needs, it’s worth checking out, but you can get as good or better performance with a self built machine.
Is it just me, or is the “No Holds Barred” system missing a motherboard and CPU cooler?
The cooler master includes a cooler but yeah I forgot a mobo, the B850i Lightning Wifi from ASRock would be a pretty good choice here, but there are a ton of good ITX AM5 boards to choose from.
I usually take on machines with the possibility to hand them over to my relatives later down the road, and Strix Halo fits in that sweet bucket where it is already built and assembled, and I don’t have to do anything to it other than hand it over to my family once I’m done with it - in a really small form factor, no build - no nothing.
The only thing I worry is that a while back the understanding was that Strix Halo was a commercial platform and all optimizations were maintained by enthusiasts rather than by AMD w/ support - however I looked at what Phoronix was doing with ROCm 7.9 under Strix Halo. Would it be safe to assume that this is going to be a “first class citizen” now that AMD has included Strix Halo in their 7.9 release?
@wendell - could you help me figuring this one out? (above) Strix Halo looks like a great platform, but I am just worried about the lack of support in the AI space - or is it a safe buy now?
I wish I knew for sure the answer to your question. Strix Halo is a case of ‘man this is a crazy amount of horsepower’ ‘if you build it they will come’ and they did, and spark is not enough faster / costs so much more the pendulum swings back in favor of strix.
The real answer is it depends on what you want to accomplish. As we did our other video you can build a better gaming machine with a dgpu for same or less money so don’t buy it for gaming … buy it because you have an interesting ai thing you want to run locally that hybrid cpu+gpu doesn’t do as well on?
Definitively not buying it for gaming - mostly for AI, and eventually as a system for a relative of mine that may benefit of copious amounts of RAM (Photoshop/Illustrator and the likes). Think this pretty much tells me it’s a viable option for what I want it to do. Thank you very much!
That FSR 4 INT8 leak for RDNA 3 and even RDNA 2 GPUs (which I believe involves many latest APUs) is very tempting for usage in cases like this. I’d love to see some benchmarks :slight_smile: Upscaled 1080p with FSR 3.1 looks bad, but FSR 4 looks pretty good even at 1080p.
This question is a little out of left field, but possibly relevant: Lenovo is advertising as a First for some their Intel Ultra Desktop CPU-based ThinkCentres (Centers) the availability of an “Optional dedicated NPU”, but doesn’t specify exactly what it is. If all it is is something that would bring those compact Desktops to “Copilot” spec, then I’d say never mind. However, what exactly is it, and are there NPUs that might result in greater increases of LLM performance per dollar than, for example, one (or more) Radeon Pro 9000?
Also, another question: is there any consumer desktop combination (CPU plus Board) that can support two of these Radeon Pros for LLM work, or is it basically only doable with a Threadripper setup?
