So I have been busy since my last post about my first full server build, an AMD 4750pro.
I went Intel this time to see if I could get better results and I love playing with hardware. All my servers are custom rack builds at a maximum chassis depth of 16". I have an 18" deep rack mounted to the wall.
And this is the rack now. I currently have cable 1gig service but they are putting fiber as we speak so I will be happy to move to fiber. I also built a opnsesnse router in prepperation for the new fiber hookup. no modem, no equipment at all. just the fiber connection to my own equipment.
I’ve heard about people doing that with fiber. Is that something explicitly allowed by your ISP, or do you have to do some weird jump start procedure with their equipment?
They came by to sign me up for the free install as they will do the hookup as part of the fiber install process. A $100 install avoided. He said they will run the fiber in the house hook it to a sfp+ adapter and it will plug directly into my OPNsense router. My home network is 10gig and supports 2.5gig and 1gig devices. My router is hooked to my cable modem via 2.5gig link. My router has instelled a:
Intel X520-DA2(dual 10gig sfp+ ports)
Intel X550-t2(dual 10gig RJ45 ports)
Intel I225-V 2.5gig single port(specifically for the Modem)
@wizarddata each fiber provider has there network setuped differently. Some ISP require you use their equipment exclusively, others you can get away with using a compatible modem and then provide your own router. I came across one company (no longer in business) where you bought your own router modem. The most common situation I have come across is either you need a modem or a modem router combo device and then you can hook up your personal device.
The only equipment they provide is the Fiber cable, the sfp+ adapter, and if needed the sfp+ to RJ45 adapter( for most consumers). Connextbroadband.com in Ogden Utah if you want to check it out. It specifically says do NOT purchase a modem you only need router, TP-LINK routers are recommended but no modems or modem router combos.
Yea fiber doesn’t need a traditional modem because you’re not modulating/demodulating a signal. Instead they generally use an ONT or an ONU SPF+ module which the ISP will supply/sell or will let you know whats compatible.
