Strap on, kids, it’s gonna be a bompe ride…
So here is my current system:
As you can see there are a bunch of issues with the way my current system is built.
The obvious issue is the fact the front mesh is kept on with some duct tape, cause the clips broke and they don’t work anymore.
The cable management is fine, but it can be cleaned up more.
The AIO is a Cooler Master, but the Cooler Master fans, that come with it are atrocious. The rotor is huge, like HUGE…
So I used a couple of F12 Arctic fans instead of the CM fans. The noise is lower and the thermals are better.
Unfortunately one of the F12 fans died so I had to go back to one F12 and one CM fans.
That’s why I bought the new Arctic fans, so I can unify somewhat the AIO…
The HDD is mounted in the optical drive bay. Once I remove the HDD I will have no need for an ODB anymore.
Also the rubber grommets seems to be falling apart.
So I will try to fix most of these issues in the new case.
I also found something I forgot I even had - a 4 fan PWM splitter. That would help immensely…
Sadly the Fractal fans are 3 pin so this PWM splitter won’t really work for them, but we shall see what I can do in the building process…
Shall we begin?
Yes. Yes, we shall…
Ok, mounted the SSD. Will attempt to wire it on the inside. If it doesn’t work I will mount it on the outside…
The front fan mounts are needlessly complicated.
On the front of the case there are those fan mount plates, that are held together with clips and screws. You remove the screws and unclip the plates and then remove the fans from the plates. They can just have the fan mounts on the front of the case, but they have decided otherwise.
The fans look really cool, tho. I kinda feel bad for replacing them…
So this is the new front of the case:
Well, I kinda expected the black frames of the fans to be more visible. Well it ain’t…
Moving on. I mounted the PSU… It’s a toiny little thing. The cabling is worrying me. Altho I am just now realizing ho much actual space there is. So no, the cabling is mostly fine.
Here’s fun
This thing seems to be dusty
Also I have not cleaned my case in a while…
Thanks to the excellent design from Lian Li I can remove the entire rear panel and work very easily on mounting everything.
Removable panels, children.
This is something you don’t know you want until you have it. And then you want the F out of it… But trust me - removable panels is a really nice feature…
Motherboard mount - EZ…
Next up - I will replace the fans of my AIO. I must say I really like how this thing looks…
Before I mount the AIO I need to deal with the cabling in the upper left corner. I don’t have an 8pin EPS extension cable, cause that is almost always gonna be covered either by the AIO or a large air cooler. So I will use the PSU cable directly.
While I was trying to deal with that, I realised things would be 173,5% easier for me if I remove the HDD cage.
Also, I can’t stress enough how great it is building a PC without having a rear panel… It’s SO GOOD…
And here we are. I can’t mount my AIO on the roof, because the ram is literally 2mm too tall.
So the new plan is AIO in the front, dual 140 exhausts on the roof.
Yes, I know it’s upside down, no, I can’t mount it the other way round.
Back panel - on…
Now there is one bad thing about removable back panels - you have to attach them later on with the rear exhaust and in my situation - motherboard backplate… It’s a pain to clip the panel before started screwing.
Now if there were screws only and no clips that would have been precisely 628,4% easier to deal with.
Now, the system is mostly done. But I need to do some cable work before I attach the two bottom intake fans.
It looks so nice…
Right. Fan controller…
I have removed the Fractal case fan controller.
The issue with it, is that there is no place I can screw it onto and I have no screws, long enough to mount it wherever, altho the issue would still stand - even if I had the screws there will be nowhere to screw it to.
I can just leave it floating in the back just like that, but I don’t like to do trash like this, so for now it’s out of the picture.
Meanwhile the rest of the system:
Remember when I said this case have way too much white and I want to focus on the black?
Yeah, I kinda tale that back…
Looks really nice tho. I like it.
It took me waaaay longer than it ever should have, but here we are.
Now the LED strips.
There is no way I can mount them in a way they will illuminate the internals.
The chamber is small and the 140mill fans will hide the strips so no light. Even if I mount it on the front, the rad and fan brackets will block the light. So no light.
It’s OK thought, cause the glass is not tinted at all.
Now I need to plug all the cables, see how it goes and will report after work.
I need to go to work. When I come back I will play around with my brand new 6 years old computer…
