The title says it all. I need the Smallest case possible to house a mini-ITX build.
The motherboard, if you're not familiar with it, can use laptop memory and a laptop power brick, so the actual case wont need to house a bulky power supply.
The only parts that'll actually be in the case:
CPU: Intel Celeron G1820 (Will use stock cooler for the build) MOBO: Asus H81T/CSM RAM: 2x2gb Hynix PC3 8500s SSD: Crucial MX100 128gb
Rajintek Metis. Small, affordable and available in many colors. Or LC-Power LC-1320II, which comes with a 90W external powerbrick. It's going to be very tight with the stock, but should work.
Those both have "extra" room for a PSU, so that's a no go. I NEED it to be as small as possible. The motherboard that I have just uses a laptop charger for power.
Pretty much the case just needs to have room for a mini-ITX board and SSD and that's it.
