Small Monitor (14-15.6) Recommendations
Anyone have any experience with some of these smaller ‘portable’ monitors? There are a plethora of them on Amazon from brands I’ve never heard of, and some from the big names, but not having as much luck finding ones that aren’t strictly meant to be portable monitors. I’m looking for VESA mounting support and HDMI or DisplayPort (some are USB-C only). 1080p or 1440p would be OK. Not a TN panel.
This weekend I decided to hook up my old 27" monitor to run as an 2nd monitor in the vertical position, and while it’s definitely nice having the screen I don’t have room for it on my desk without having to shove one of my speakers behind my main monitor, which I don’t like.
Something in the 14-15.6" range would give me more options, especially if it’s got VESA mounting support. I could mount it on an arm above the speaker/next to my main monitor [one on each side possibly]. Or worst case scenario I could fit up to a 15.6" underneath my main monitor with it just sitting on my desk.
