Small homelab, help needed regarding networking and virtualization
Heya, so I’ve got a spare computer from a neighbor recently, (i7-9700, 32GB DDR4 - Dell XPS 8930) and at first I thought homelab, Proxmox/XCP-NG, etc and discovered it can do IOMMU things. So then I thought, “virtualize the router.” Given the locked down abomination that was thrust upon me by my ISP recently, among other things, I figure now is a good time to figure this out and more advanced networking topics.
I have no networking equipment whatsoever, and this is really my first foray into actually engaging with this rather than just reading about it (I have used DD-WRT in the past, and done some things with networking, but I’m still very naive). I have some experience with KVM via desktop Linux (VirtualBox too, of course), so I’m not terrified of VMs, CLI or containers for that matter. I had a box set up before with openmediavault, a 2x1TB RAID0, managed some docker containers (and built a container of my own) and shoehorned a Debian VM for pihole onto it; just to give a very shallow overview of what I’ve already done here.
My basic goals here are “simple”, I hope; clear at the very least. I’d like to end up with a virtualized router with a PCI NIC passed through to it and some VLANs. The rest of the small lab will follow with VM/containers. Posting here however, I’d like advice, opinion and some direction; like should I even bother at all and just get a standalone router and use this spare computer for VM/etc, for example. I’m torn between Proxmox and XCP-NG, pfSense and OPNsense, then the ball is in the air in regards to the hardware. I know I’ll need a PCI NIC, switch (managed or not is questionable, but for experience maybe managed?), and a wireless AP. I’ve found some opinion already regarding updates and methodology of the software, and while I would like opinion on that I have to say the networking hardware is where I’m really out of my field. All that said: I’ll also take flat recommendation for an “AIO” router for the “not bother” case or the “in case shit happens” case, which it plainly will.
Thanks for your time
(Didn’t know where else to put this since it involves a couple of topics, hope the DIY Corner is ok)
I don’t personally like virtualizing the the router, especially on the same box as everything else. You will need an update, new driver, the configuration will be messed up, and you will need internet access to fix it, but the router VM is down unless you fix it. Then you are trying to do some type of network bridge with your phone. It turns into a pain.
https://mikrotik.com/ makes some really nice routers with every option under the sun. Warning, there is almost no hand holding with it’s software, so expect a big learning curve.
Proxmox has the most community support right now and what I would go with. I am retiring my last XCP-NG box in a few weeks.
Yup.
It is proper big-boy gear in that regard. You either know what you are doing, or will have to learn after that config change…
Yep, first thought I had as well. A homelab proxmox machine is nice for screwing around, screwing around will inevitably break things, and all the easiest fixes usually require the internet to look something up or redownload whatever you broke. Separate the internet box from the fiddling box, you want them to break independently from each other, not together.
That’s what I do…
The forbidden router is forbidden for a reason, it’s a fun idea but best avoided imho 99% of the time
To add to your options for hypervisor setups - Alpine, Debian - is more learning involved, or at least used to be before we had pretend intelligence.
If you want to step into networking I’d start with a discrete router and maybe a discrete switch depending on the router and network. Dumb switch is a fine start, they’re very cheap and useful to have around even if/when you buy a managed switch.
I can definitely see how that could be an issue. It’s part of the reason for the last sentence I wrote as I don’t have a backup if things were to go wrong. Seems as though everyone else agrees. It does beg the question though, virtualize the router on a separate machine? I’m only stuck on virtualizing for potentially simpler disk backups. It would also mean I’d go for a thin-client or something more specialized; I don’t have any low-power computers lying around unfortunately.
Regarding MikroTik, I’ve heard of them before, but it’s not a exactly household name for me so I’m a little iffy; unjustifiably probably lol. How are they affected by the FCC shenanigans though? Current hardware can continue being sold, but software updates have a limit for current hardware (I did just read that it was extended until 2029 from March 2026). These shenanigans are partly why I was leaning into the “build it myself” idea here. That said, I do like the look of what’s offered with their hAP be lineup. The lite doesn’t break the bank and the Media offers some niceties at a surface level. Their RouterOS seems to be closed source, or their parts of it at least; I know the kernel is available. Not a hard requirement to be open source, but in current times it’s a boon at least. As far as the learning curve, well I am green. I might be learning after each config change like MazeFrame mentioned lol. I’m not sure where I could go beyond VLANs currently, but if I can restore to a functioning state in an easy way then I’m game to hit the find out portion often.
Is it strictly community support that’s causing you to switch away from XCP-NG? The biggest hurdle I’ve read regarding XCP-NG was learning their tools. I’d rather not end up fighting their system while working with the underlying Linux, assuming that’s a possible issue here.
Never heard of it as “forbidden” lol. What I’ve found on youtube make it seem more commonplace, but the algorithm can be pushy.
Wouldn’t the Alpine and Debian setups just be XCP-NG, but more manual? I’m not opposed though, could make it a fun learning experience.
What would you suggest as a discrete router? And switch for that matter.
And on the forums someone more experienced about mikrotiks will probably tell you that you should have used Safe Mode to avoid locking yourself out. :rofl:
Not on the good boys list https://www.fcc.gov/supplychain/coveredlist#conditional-approvals so us sellers probably cant sell you newer stuff.
Worth noting FCC ban affects only US sellers, you are free to buy whatever you want from overseas sellers. If you want some china special Tenda router or questionable managed switches with funny names, or anything else, you can still buy it.
Should not be necessary for any of the usual suspects (pfsense, opnsense, openwrt).
Any self-respecting router os supports config backup and is mostly static. Similar to a router box you buy.
If the disk dies you can just re image a new disk, restore config and you are up and running in 10 minutes.
My God, this. Virtualizing your router guarantees your entire network gets automatically Stone Aged if something happens to that machine. Sure, hyperscalers do it, but hyperscalers have redunancy and instant failover.
If you’re looking for a router, my recommendation is an Ubiquiti UniFi Cloud Gateway Fiber, which is what I use. The stability and performance are top class for gear you can easily deploy at home and what it lacks in features it more than makes up for in reliability.
What! See video - Forbidden Router: Container Host VM (LanCache/SteamCache + Pihole) and Portainer for management
More manual, but more choice/flexibility/minimalism and much more learning. For instance my setup is exclusively PVH and dom0 has no IP and is managed over serial, my desire is to hopefully reduce exploitable surface area. I’m not sure how much of that I could do with xcp-ng, PVH support last I heard was coming..
The regular Xen tooling I find quite pleasant, for instance a VM config is just an approachable text file.
Not sure. I avoid the regular proprietary or consumer level software choices. I went with OpenBSD as an Internet facing router and OpenWRT for wifi router. Recently got a Flint 2 which has been much more impressive than my old wifi router, it has a switch built in - you can see the block diagram here. I think that’s a reasonable candidate - has a sizable (for a consumer router) amount of CPU/memory/disk/ports for you to work with.
I would like to Zag.
I think you should do the Forbidden Router. Yes, you’re always under threat of everything going down if you decide to change hardware or fiddle with it. But that is a good thing!
There is nothing that can train you like when all of a sudden nothing works and you have to think your way through it.
Because one day you will have some sort of rug pull and you’ll have to think yourself out of it – and guess what – The Forbidden Router will have prepared you for that moment.
There is no single project I have undertaken that has trained me in the art of hardware/networking/software amalgamation as hard as the Forbidden Router.
So if ya wanna take the path of least resistance get a Protectli, put pfsense on it, and have Network Chuck guide you through it like a coward (/s), fine. That’s likely the prudent choice.
But if you wanna be a Network Marine — The Forbidden Path awaits.
I don’t like virtualization for nas / data storage for a couple of reasons.
  1. it’s a vm and it depends on 1 or 2 extra software layers that just make it that more complicated and easier in my mind to mess up your data or loose all access to it.
  2. I don’t like it shared with other running applications. if one of those applications goes sideways / compromised then there goes your your data.
My $0.02 for what it’s worth!
I’ve heard of Ubiquiti, and I’ve only loosely read into them. Looking at what you mentioned, I figure the step down, Cloud Gateway Max, would fit me the best at least in terms of pricing. Though, I would definitely need a wireless AP to go with it. What kind of features does it lack? And, silly question: Are they more of a walled garden or do they play nice with other brands/systems? I only ask because I’m vaguely aware of their ecosystem, and that their AP’s want a controller on the network somewhere.
Oh wow, 4 years ago lol. I get what he, and everyone else, are saying. The “like a toaster” thought is the better argument against this; still looking at the “here’s 3 things I’ve never implemented” thought though because learning and whatnot.
I think I’ll put the manual Xen on the list of consideration, but I think I’m leaning more towards Proxmox for now. I do like that VM config though; in the man page it looks like PCI passthrough is simple enough to configure too. Maybe on another computer, though the next best hardware is an Ivy Bridge i5 (K SKU) and i3.
That does look like a nice option that I’ll definitely look into more. I know they use a modified, and older(?), OpenWRT already. It’s a matter of how easy it is to get “stock” OpenWRT on it for me at least.
The devil’s advocate post. The goal is definitely learning, but also to get something that’ll work well. Maybe I’m underestimating the difficulty and complexity here. I’ve walked into most things with a “that can’t be too hard, right?” mentality and quickly ran into the brick wall and have come out with the goal completed, but they were also smaller projects (like the docker image I mentioned in the OP). How “well” they were done, I’m not sure, but they worked at least.
Protectli looks very interesting actually. The price seems a little wild, but I do like the apparent flexibility it seems to offer. (momma didn’t raise no coward)
If you really want to min/max hardware you have, running two router (opnsense/pfsense) VMs using the router built in fail over is best IMHO. Two proxmox nodes with similar NICs are mandatory along with a vlan capable switch. You don’t need proxmox fail over or a proper 3 node setup. There is a L1 video on that setup somewhere.
Appologies, no shade intended. I enjoy going for a stylistic prose.
I like the Protectlis because they are just mini pcs except that they test their hardware with pfsense, opnsense, and a few other open source firewalls. So, they are built with firewall security in mind, but one day can become something else. The builds are nice and they feel like the quality. They beep when they turn on or reboot which is great for security (no shadow reboots).
I also like mini pcs for a firewall over a virtualized setup because the power cost is (probably) lower.
If ya wanna minimize cost, you can totally put an open source firewall on a different mini pc. And while latency might suffer a bit, 2.5Gb internet is well within the capabilities of the DDR3 generation.
Looks like you can get a pretty cheap mini pc on ebay. Tho you will want to make sure it’s not vendor locked or something – you need to be able to install a different os than comes stock (your open source firewall) and the device needs enough ethernet ports that are fast enough for your setup.
I would also keep in mind that a too-cheap-to-be-true mini pc is a surefire security risk these days.
IMO, not ones that most people use. But if you’re the type of person who has OPNsense maxed out in terms of functionality or are used to VyOS or Mikrotik you might find it limiting.
You can control only UniFi devices through the UniFi OS Server dashboard, but 3rd party devices show up just fine and UOS supports SNMP so you can use that too.
I run it with a completely separate Pi-hole + unbound DNS and also Wireguard VPN and everything works swimmingly.
Yeah you can either run that on a Gateway that supports that or self host it. The controller is called UniFi OS Server (UOS). I run it on a Mac Mini. I prefer to self host as that way the router having an issue KO UOS, and I’m also much less limited by the router’s RAM and CPU.
In theory. In reality running enterprise gear in the 1st place prevents 99% of weird issues in the 1st place. Also “have to think your way through it” is frequently the result of DIYing in the 1st place. Your ISP can’t help with your self hosted DNS, for example. In other words, going hardcore frequently creates the situations it supposedly trains you for, and you can avoid those by not doing so in the 1st place.
Rather than preparation, I encourage DIYing because it gives you control and, if implemented correctly, higher reliability. For example, IME self hosted DNS is much more reliable than ISP DNS and works exactly the way you want. It’s also a great way to learn how 1 of the fundamental technologies of the internet works.
I’d say you should attempt the forbidden router but also buy a standalone something from glinet or a company that allows you to re-image the router with openwrt in case the forbidden router thing blows up due some unholy things you’re doing to the configuration, from a security perspective, though if you’re gonna do the forbidden router, don’t host anything else at least nothing with sensitive data on it cause one if a bad man from across the world gets access to one thing he can compromise the entire network and probably take your data
I would recommend : GL.iNet Slate 7 Pro (GL-BE10000) Wi-Fi 7 Travel Router, 6GHz, 2.5G, OpenWrt
It’s small so it’s compact won’t take up much space in wherever you place it and it will be a safe failover.
