Hey logan, wendell, qain, pistol and the tek community . I've been wondering about this for some time now. It is better to do a complete upgrade from a 4 year old computer, or replace parts slowly?
It depends on your budget and what you really plan to use your computer for.
Depending on your current (2009) parts you could probably buy it in stages and it work out in the end...
- you can buy cpu, mobo and ram (if your computer uses ddr2 still), and use your old gpu, psu**, hdds, and case;
- buy a gpu (and a psu now if needed for the gpu);
- buy a sdd/hdd and psu (if not in the step before);
- buy cpu cooler (if you want to OC and/or care about noise) and a case (if you really want to upgrade it for whatever reason);
- Profit?
**depending on the mobo/cpu you are buying you may have to buy a psu before/with the cpu/mobo/ram step...
And look you have a new system upgraded over time while still being usable between each step... and each grouping is split in to (what I would consider) affordable price chunks... so over the course of a few pay checks you have a nice computer at the end
Although depending on your systems specs you might be able to just slap a new gpu in there and call it good for a while yet... (until you can save up for the other parts)
heres the stuff i have right now:
lga 775 quad core q8200, asus p5g41c-m mobo, 2 ddr3, amd 6790, 1tb hdd, some seasonic 550 watt psu.
I've got almost 500 saved in terms of upgrading something. Either a gpu or a cpu-mobo combo.
http://pcpartpicker.com/p/236hZ
CPU AMD FX-6300 3.5GHz 6-Core Processor ($119.99 @ Newegg)
Motherboard: Asus M5A99X EVO R2.0 ATX AM3+ Motherboard ($109.99 @ NCIX US)
Memory: Kingston Blu 8GB (2 x 4GB) DDR3-1600 Memory ($64.99 @ Newegg)
Video Card: MSI Radeon HD 7870 2GB Video Card ($179.00 @ Amazon)
Total: $465.97
Wow, thanks for the link cooperman, this makes it much easier to find parts.
