Sleeping Dogs
I recently bought sleeping dogs, during the steam summer sale, and just only got around to playing it. When i try to the play the game, the game window opens but all i get is a blank screen i once let it sit for 10 minutes thinking that it just needed sometime to start, but it never started.
I have downloaded the latest nvidia drivers, if it makes any difference i have a 700 series gtx graphics cards.
Does anyone know a fix to this? any help would be much appreciated. Thank you!
"I think i've found a solution for Windows 7 users who still are having the black screen issue, go to your Steam folder -> steamapps -> common -> SleepingDogs then go to HKShip.exe -> Proprieties -> Compatibility, then mark "Deactivate Desktop Composition" and "Run this program as administrator"."
Crossposted from the Steam forums. If you have Windows 8 then you can't do this. I find it's also worth launching Steam as an admin then launching the game, which sometimes works.
Other things to try:
1. Validate files through Steam.
2. Try without High-res texture pack if you are using it.
3. If you are using DLC make sure the DLC is in the root game folder.
