Skyrim Mods
I very recently got Skyrim Legendary as it was on sale recently and I really should have gotten it a very long time ago. I got NMM running and loaded up the Better Shaped Weapons mod. I'd very much like recommendations for other visual mods and I'd very, very much love a fix for the double cursor issue that occurs like 5/6 times you boot up the game.
PC specs: watercooled FX 8350,  8GB Ram, Powercolor Devil R9 270X and something like 800Gb of free storage on my D: Drive
https://teksyndicate.com/videos/logans-skyrim-mods-v2-enb-ini-settings-tweaks-everything
a lot of the mods that i run i got from Logan's mod list. except for the enb, i run realvision enb which you can find here http://www.nexusmods.com/skyrim/mods/30936/?
Double Cursor Fix: http://www.nexusmods.com/skyrim/mods/36125/
I started a thread about people who are new to modding skyrim but I will post it for you here as well.
Here are some GREAT sources to get you going.
 gopher is very in depth ,helpful and will guide you step by step on the entire process including load order and how to get everything you need.
https://www.youtube.com/watch?v=RxQ1JN_X-_Y
If you have a high end rig and really want skyrim to look truly amazing check out this video.
https://www.youtube.com/watch?v=O_gqhkELdIE
I would for sure check out Gopher's videos and Logan's modding videos. A lot of info. As far as visual mods I'm using most of what Logan uses, but I'm using z-ENB instead of his(major frame rate boost).
