buy or have a auto leveler
if you have a glass bed replace it after a while
do not expect gods work with filament go resin if you want resolution
LEARN BLENDY
play with friends and ask for help after you learn a tiny bit you can go far learn alot you will cry and want a better printer and hate yourself
you CAN repair everything that doesnt mean you will
you will make alot more organizers and cases then tools
I have a .3 on the ender and .25 on the prusa mk3 at the office
These were done on the mk4 with the .4 nozzle, it can’t use any smaller because it has a MMU on it and prusa doesn’t have a profile for it
The pictures are called hueforge, you don’t need an MMU but it does automate it
