Single monitor arm for top dual monitor or a dual monitor vertical arm (34inch lower & 27 inch upper?
Hey All,
I am wanting to pick up a monitor arm primarily for a top monitor (27 inch) above an ultrawide.
I have been looking on amazon however its find of hard to gauge how high the arm will actually go.
It also appears some of them are deceiving in that they go up but the arm/mechanisms dont really make them go much higher.
At the moment I have a 34 inch old TV that is on some legs which are wood.
It has worked and been hidden behind the monitor however I am re-doing my desk setup and the wood is unsightly when its viewed. It served its purpose and now its time to go
I dont mind if there is a dual vertical monitor mount but I likely can just sit the ultrawide on its stand on the desk so i am not quite fussed. Its mainly to have the top monitor look nice hanging above the ultrawide.
I ended up ordering this one.
The reviews seem okay on Amazon.
will see how we go :slightly_smiling_face:
Dual Monitor Stand - Vertical Stack Screen Free-Standing Monitor Riser Fits Two 13 to 34 Inch Screen with Swivel, Tilt, Height Adjustable, Holds One (1) Screen up to 20kg HT05B-002P… https://amzn.asia/d/cZIadsu
