Silverstone WS380-E Build Similar to L1T Video, and 3D Printed air cover
Hello fellow forum weirdos,
I watched Wendell’s excellent ‘Their Server Died. The Supply Chain Said “Good Luck.”’ video when it dropped and was excited that he was building a server that nearly aligned with a project I’d been researching, and collecting parts for, for my homelab for a months.
Specifically, a new NAS build that would support 11 spinning rust disks, and a radiator to minimize the noise. This NAS will also eventually connect to a JBOD DAS so it is going to have a lot of PCIe components. Wendell’s build was going under a desk, but mine is going in the primary bedroom closet, and so the noise level needs to pass the spouse test.
I’ve assembled everything but I’m a little concerned about my PCIe and memory thermals. In the video Wendell mentioned that he might 3D print a cover or something to direct the air over the RAM, so I figured I’d hop on the forums and ask:
Did anyone else build something similar, and if so, did you 3D print a cover to direct the air better over the memory and PCIe slots?
If you’re still with me and answered yes to the above, can you/will you share the STLs for printing?
I’ve repasted the heatsinks on HBAs and Mellanox ConnectX with some extra Honeywell PMT 7950 that I had from previous builds but I want to try to maximize what airflow I can over the components.
NAS Head — Hardware Configuration
Component Detail
Chassis SilverStone WS380-E, 8× hot-swap 3.5" bays
Bay expansion SilverStone FS303 (5.25" → 3× 3.5") — 11 internal bays total
Motherboard ASRock Rack SPC621D8-2L2T (Intel C621A, SSI-EEB, LGA4189)
CPU Intel Xeon Silver 4309Y — Ice Lake-SP, 8C/16T, 2.8 GHz base / 3.6 GHz turbo, 105 W
CPU cooler SilverStone XE360-PD 360 mm AIO
RAM 128 GB DDR4 ECC RDIMM — 4× 32 GB, 4 of 8 slots populated
RAM part Samsung M393A4K40CB2-CTD7Y (2Rx4, PC4-2666V, CL19, 1.2 V, IDT RCD)
RAM relabel Lenovo TruDDR4 — option 46W0833 / FRU 46W0835 / spare 00NV205
PSU be quiet! Dark Power 13, 750 W, 80+ Titanium
Case fans Noctua NF-F12 iPPC intake w/ shroud; spot fans over both HBAs
Onboard NICs 2× 10GbE (Intel X710) + 2× 1GbE + dedicated IPMI — all PCH-attached
HDDs 11× WD/HGST HC550 18 TB SAS3 — dual RAIDZ3, ~144 TB usable
NVMe 6× Intel Optane P4801X 100 GB (M.2 22110) — 4-way special mirror + 2-way SLOG
OS Proxmox VE + ZFS native; all NVMe and HBAs CPU-direct
Power draw ~220 W idle / ~300 W typical / ~400 W peak (estimated at the wall)
PCIe Slot Occupancy — 56 of 64 CPU lanes used
Slot Width Card Notes
SLOT1 x16 Mellanox ConnectX-5 MCX555A 100GbE QSFP28 ~18 W with optics, passive heatsink
SLOT2 x8 Dual M.2 carrier → 2× Optane P4801X (SLOG) Bifurcated x4x4
SLOT3 x8 empty Robbed to x8 by SLOT2
SLOT4 x8 Broadcom 9400-16e HBA (external JBOD) Phase 2
SLOT5 x8 LSI 9400-16i HBA (internal HC550s) ~10 W, runs hot
SLOT6 — empty — must stay empty Keeps SLOT7 at full x16
SLOT7 x16 Quad M.2 carrier → 4× Optane P4801X (special vdev) Bifurcated x4x4x4x4
Any help is appreciated and thank you!
you having trouble with it? I have the fans up kinda high and at that level of airflow I haven’t needed any baffles. so far.
Where did you end up getting the Silverstone WS380-E from? I’m looking to get this case for a build also, but not finding it for less than around $800 USD.
The thermals are tolerable at the moment, and I’ve just been doing burn in.
I haven’t swapped to the Noctua fans on the radiator yet, similar to what you did, and the stock SilverStone fans a a lot louder than I anticipated.
I’m also going to try adding the PCIe/GPU extractions fans accessory, swapped to Noctua 80mm, to see if that lets me run all of the fans at a lower RPM while keeping the Mellanox ConnectX-5 happy. That’s the card I’m most concerned about running hot.
I urgently needed the chassis as I had every other component, so I, unfortunately, had to pay the Amazon tax to get the case fast. It was well over the $800 you mention, plus tax.
So far I’m VERY happy with the chassis.
