Hello everyone here,
I really would like to have some help with building my own NAS / small home server. Previously I has an very old QNAP and I just sold that. I wasn’t happy with the QNAP at all. Now I am sitting here with a bunch of HDD and some Raspberry Pi
My Plan
I want to build a medium budget NAS that runs TrueNAS with some virtualisation. I already bought the Silverstone CS382 case, because I found it to be not too huge and quite practical.
The basics
Info
Description
Budget
~1500€
Location
Germany
Retailer
Mindfactory, *
Not Retailer
Alternate
Usage
see detailed table below
Overclocking
No. Energy efficiency is a focus, and IPC/Watt
Water-Cooling
Might want to use an AiO to remove heat more efficiently (not sure
Gaming
None
Transcoding
If possible 2 simultaneously 4k hevc → 2 1080p h264
Render-Server
Not planned
Case
Silverstone CS382, It limits me to µATX but it’s doable
Usage
Details
Storage
I already have a few HGST and Seagate IrionWolf Pro drives
Media Streaming
I want to move my S3-Bucket-Hosted movie library to local storage and continue to use Jellyfin
Virtualization
I have a few Rasberry Pi that I like to decommission
DNS-Sinkhole
Currently running Pi-Hole that I would like to virtualize
Unify Controller
A unify AP Dashboard is running on a Pi. This I like to virtualize, too
Home-Automation
I have a Home automation docker container that I’d like to move to a VM to take fully advantage of that purpose built Appliance
Backup
I want to have automatic incremental backup setup that gives me Timemachine like options natively on linux
Photo Archival
I am not a fan of the G Suite therefore I’d like to store a copy of my mobile photos locally
DSLR Archival
I am shooting RAW and 100Mbit hevc video. I’d like to make a long tern storage for that
The setup that I was thinking of
Type
Item
Reason
CPU
Ryzen 7 9700X
Latest modern CPU with a relatively modest 65W TDP but a high core count
RAM
DDR5 192GB (4x48)
Higher than a typical NAS needs, but this should also be capable of some virtualization without getting into Epyc or super high TDP
ODD
9.5mm slim LG BU40N
The system should function as BD ingest station
MB
Maybe Asus B650?
GPU
AMD Radeon PRO W7500
1 slot high, only needs PCIe power
NIC
Melanox?
Upgrade to 10GBit/s, should work with linux OOTB
HBA
some LSI variant, buying used on ebay
having enough ports for backplane + have MB ports available, flashed in IT mode
I am really unsure about
what motherboard to get
If an AiO radiator isn’t a reliability nightmare
are there silent 3.5" drives which aren’t sata SSD
do I go with a caching m.2 nvme or optane
aren’t there any 5 slot PCIe boards?
do I need 1x16 (GPU) and 2x8 (HBA, NIC)
using the 5.25" as card reader module
This took me super long to write down and digest in the most concise format. I hope I put all needed information in here and I am really looking forward to your help and support and inspiration
Look at using copy-on-write (COW) file systems. Btrfs and zfs are prime candidates, zfs gets a lot of air time on this forum.
Look at Immich (especially if you have iOS devices).
On consumer boards using 4 sticks of DDR5 will limit data rate to DDR5-3600. Generally, you only want to use it if you really need it. Also, each RAM stick uses ~5W power - you need to take that into account for a low-power NAS.
This is the biggest puzzle piece. Full featured mobos will draw a lot of power for all the onboard components and to reach PCIe gen 5 speeds. IMHO there are no good boards for a NAS on AM5, but that really depends on your exact requirements.
A NAS, even with your requirements, doen’t need tons of CPU horsepower. If you run into limitations on AM5, consider the older but still viable AM4 platform, which is much cheaper and has plentiful options.
Mellanox NICs should all work ootb on Linux. Look up the specs for their power draw.
Again, look up the power draw. Consider looking for a mobo with plenty of SATA connections, consider an m.2 to 6x SATA connector for reduced power consumption. LSI HBAs are super reliable and performant, but not power sippy.
On consumer platforms? No. The CPUs are limited to 24 to 28 PCIe lanes in total, a single PCIe slot can have up to 16 lanes.
On AM4 there are rare boards that offer 3x PCIe Gen4 slots with 8 lanes. But more likely you’ll find 2x PCIe slots with 8 lanes, a third with 4 lanes. Often the slots are bifurcation enabled, meaning a single slot can address more than a single device enabling e.g. cheap adapter cards for multiple m.2 or u.2 nvme SSDs.
On AM5 most boards are very limited in regards to bifurcation, number of PCIe slots and lanes in favor of on-board m.2 slots.
As explained above this config is not physically not an option on consumer boards (Intel and AMD).
A good compromise for a NAS is to use CPUs with build-in iGPUs.
Thank you very much for your in-depth reply. It helped me to understand things more clearly. Unfortunately, I suddenly receive a bit of a time-crunch to get the system done… so I couldn’t go as much in perfectionism as I would have liked, but that’s okay.
I opted to go with only 2 DIMMs and found a reasonable efficient PSU. So wish me luck for the build of the machine.
TDP doesn’t take into account power consumption, it’s just an indication of what kind of cooler will cool the CPU enough to keep it at base clock and not thermal throttle.
Usually for 65W parts AMD uses 88W PPT, which is the maximum power the CPU is allowed to pull. But it’s also a great starting point because with some negative curve optimizer or flat negative voltage you will get lower peak power consumption.
Depending on what PSU you got, idle power consumption can be significantly affected. Especially because AMD parts do not idle as low as Intel parts do.
Beside this I fully endorse Jode in their assessment. Great suggestions all around.
