The Background
As some of you are aware, I’m looking to do another build in the near-ish future, but I’m trying to do as much research as possible, previously I had my heart set on something that involved the Fractal Era case. It seems great for what it is, obviously it’s not targeting high airflow or anything along those lines, hence why if I were to go with a build along those lines, I would probably have to go for a GPU like an EVGA Hybrid, with the 120mm rad. But then I looked up how bad the pump noise was, hell no!
However, I’m all for having an insane system in a small form factor, but there’s one thing that annoys me more than anything, the sound of a system. It really is stupid to think that I’d probably be happy to spend a hell of a lot of money or sacrifice on performance to some extent just to achieve silence or as near silent as humanly possible.
Anyways I wanted some general advice & input. I was honestly considering the Streacom DB4 with perhaps an Intel i9 9900T, considering the i9 9900T has a TDP of just 35W. I know that with Intel specifically, they’ve changed their general definition of TDP so when the CPU boosts it exceeds their stated TDP. But even then, I think that CPU would generally be fine for that case, especially if the additional cooling solution(s) are to be purchased for the CPU. I can’t remember the name to save my life.
The Hard Part - GPU
I’ve honestly been thinking about using a GTX 1650 as the GPU since the case is capable of cooling this GPU, but then you’re sacrificing quite a lot on performance in games. I’m not a hardcore gamer by any means, more of a workaholic, but I currently use a 1440p monitor.
So, from my research I’m either limited to constantly thermal throttling an RTX 2060 mini with passive cooling & underclocking, in which case, would it be worth having the RTX 2060 over the GTX 1650? - I’m struggling to find any clear answers to questions like this.
Alternatively, would you suggest that I try something like an external GPU enclosure? - I know they’re not by any means cheap & you lose a considerable amount of performance due to using thunderbolt 3 instead of PCI, not to mention other variables that come into play, such as interference & whatnot. However, I just feel like an external GPU is kinda cheating, since I could hide the enclosure to at least dampen the noise to some degree or another, etc.
What would you guys suggest for the GPU?
I found this build, but as he’s done, he switched out the RTX 2070 for a GTX 1650 to achieve a totally silent system, I’d like to do that, but I want to achieve at least 45-60FPS on max settings at 1080p, I’ve seen some very mixed reviews about the 1650 which is a big part of the reason why I’m here, asking you guys for your input!
Final Note
Honestly, I annoy myself with how god damn picky I am about my hardware for my setup, I can totally appreciate if you too find my pickiness incredibly annoying. My core goal is silence & a reasonable amount of performance, price isn’t such an issue, I mean within reason of course, obviously I don’t have like £10k to go and spend on just the hardware for my build!
