Hello everyone!
I've seen so many cases, but i just can't seem to come to a final decision. That's why i'd love your opinion!
I'm looking for a silent case where all my components will fit with no issue!
This is my build so far: http://ca.pcpartpicker.com/p/1UZo7
Thanks in advance for all the replies!
Nanoxia Deep Silence and if you can't find one grab a Fractal Design Define R4
You could also look at the Corsair 330r or the 550d but the other two are better.
The other brands that use quality sound insulation in their silent cases are Silverstone and Lian-Li but they are expensive.
Silent cases are a bit of a con tbh thay just muffle the sound and are not silent you will be better off filling your case with noctua fans runing at a low rpm but the Fractal Design Define R4 is a nice case regardless.
After years of research and experience I've come to a final conclusion: Buying a "silent"-branded chassis does not make your system any silent.
Judging by the components you have selected, your system will be louder than what I would have liked for a silent PC.
EDIT! BTW, go for the Core i5 4670 and get a beefier GPU.
