PSU: Silver Stone Strider Gold Evolution, 850W, 80+Gold
Case: NZXT S340
For the past two years, I have bought and acquired all the parts in the PC above. But is still needs work, so I want your feed back. The GPU and cooling needs a complete overhaul, I need more than double the graphical compute power and my entire system to be silent while on idle, keeping in mind it is a white and black themed build and I'm an AMD fanboy.
My idea, as far as upgrades go. For the GPU: Sapphire Tri/Vapor X R9 XXX
Case lined on every spare inch with noise dampening foam.
For the CPU, some form of AIO (preferably NZXT)
Case and rad fans, I need quite, high airflow black/white/Black&White fans.
In my experience the GPU always produces the most noise. So maybe buy a reference card and use the money you save on a 3rd party cooler? I have the Raijintek Morpheus installed on my gtx770, it is silent at idle (by silent i mean the hard drive makes more noise) and at full load it is barely noticeable. It will of course depend on the fans you mount on it.
I use a PWM fan adapter for the GPU fan power out (link below) which connects to a PWM y-splitter and the two PWM fans are connected to this. That way you can control the fan speed from MSI afterburner or similar.
