Should I spend $4000 on PC
I have the money for the build, but the thought of spending that kind of money doesn't sit right in my stomach. I am in college and will be starting engineering classes soon so I might be using Auto CAD and I would like to do some video editing.
http://pcpartpicker.com/user/Fink/saved/2FoN (With either 3 1080p or 1440p monitors)
(i plan on waiting until Black Friday / Cyber Monday to see what kind of deal they have)
So whats your opinions, should I do it? I love computers and would use the hell out of it. I would like to hear what you have to say good/bad, and I'll reply to your comments.
If you will get good use out of it and feel that spending that wont hurt your financially in any way go for it.
What are you doing that needs 2 x 780s and 3 monitors?
why micro atx ?
Because he can.
lol it just seems a waste :) also he may not get as much freedom with slis or anything
micro atx/mini itx is good for college because its small and portable.
hes got a mid tower case...............
If it is for school and your going to use it after then you should get the best one you can mange at the moment, but don't force yourself to spend $4000 if your ok with $3000 or $2000 then don't waste money.
I thought the 350d was a matx case
the money used is the money left over after paying for the college classes, and I'm living with parents so other expenses.
Gaming / editing. Is there anything else I could do?
I'm not forcing myself, everytime I think of a different build it still come to be quite expensive.I was first thinking of doing a mitx build with a Titan(because its a blower style) but that I saw tek syndicates video on the three monitor display and came up with this.
I want to do a small form factor that is still able to do three way monitors. I am really worried about how close to video cards are and how that's going to affect the temperatures.
what do you mean that I "may not get as much freedom with SLI or anything"? Please explain, it is very important to highlight the negitives of this build.
Just strikes me as overkill for gaming and you engineering degree won't require anywhere near that rendering power.
From your OP I assumed you were looking for ways to get the price down.
What I would suggest: Build a computer with a single GPU and a single 1440p monitor. See how you like that. If you want to add more monitors, then go for it.
I was planning on buying just one 780 and using my old monitor and after winter break when the next semester of classes starts, I was going to get the monitors and the second gtx780 together. if I were to get the 1440p monitors they were going to be from the one seller on Amazon that Logan recommended. If not them I found 3 1080p monitors that can do landscape and/or portrait.(in parts list above).
Why do you want 3 144 Hz. monitors? That's gonna need a lot of power. Are you only going to play minecraft?
If I were you, I'd get some cheaper monitors, preferably IPS, and spend my money elsewhere.
I personally recommend the LG IPS237L. It has quite a small bezel (<10mm) and looks really good.
http://pcpartpicker.com/p/1TUww This is about $500 less expensive.
- EDIT: The IPS237L wasn't available on pcpartpicker.com, so I picked something else. I have no hands-on
            experience with this monitor. I know these monitors are quite small (21,5"), so maybe you should
            pick something else.
thanks I'll take those monitors into consideration.I went with those because they were able to swap between landscape and portrait and they look like they could fit on the desk without taking up too much space.(144 hz and the one millisecond blah blah blah is just a bonus)
