Ok so I put a small dot of thermal paste in middle of my amd fx-8350 CPU but I think I put too much so i pressed down my heatsink which is the Cooler Master Hyper 212 Evo. They say your only meant to put up and downwards pressure and never right and left but to fit the bracket in i had to move the heatsink a bit to the right and left to fit it and eventually I started seeing some thermal paste coming out of one side a bit But I cleaned it off a bit with a cotton swab. even if I do reapply I don't think I'll be able to fit the bracket onto my ASUS M5A97 EVo R 2.0 Socket AM3+ Motherboard without moving it right and left it literally just about fits. So even though I started to see some come out of the side do you think I should clean it all off and reapply? Which one of these reactions should I have
1: Eh Don't worry about it it will be fine
2: Meh get a program that tells You the temperature of your CPU and if it starts getting too much try reapplying
3: STOP WHAT YOUR F***KING DOING AND REAPPLY NOW!!! BEFORE YOU BREAK SOMETHING
Personally I would go with 2 but if you know otherwise tell me
