hi im new to the teksyndicate website but have been a fan since the start, i just want to know if i should spend a bit more money and invest in better case fans heres the 2 im looking at also if you have any suggestions on fans that would be good (preferably coolermaster ones)
Fans: Coolermaster Value 4x 120mm (1200RPM) $33.50 Or Coolermaster 120mm Turbine Master (1800RPM) ($15 Each)
also im from australia so if you have links ones that can be delivered to australia would be great ! Thanks :)
(PS: i have a few steam keys to give away to people who provide the best anser)
Lastly My Specs Are :
Coolermaster Storm Scout 2
Asus H61M
Intel G640
Stock Intel Cooler
4Gb Generic Ram
Coolermaster Thunder 500w PSU
Gigabyte Nvidia GT630
(i know there not the best specs but most parts are getting upgraded shortly)
Well.......What have you got in there now, what temperatures are you getting at the moment, what are noise levels like (and how important is that to you?) what makes you think you current fans are not upto the job?
Well the normal temperature is around about 36 and max is about 50 when on full load for hours and well at the moment i only have an old coolermaster fan which is an exaust and dont have any intakes (orded 2 sickleflow for intakes) in terms of noise there about what youd expect but i wouldent mind if the were a bit quiter (ive got a fan controller which kinda takes care of that )
EDIT : i think its a resonable tempreture but id rather keep it as cool as possible
Well in this case you don't need to really switch out the fans for temps, as you are going fine with what you got, and replacing that stock cooler would do better for you temps then a new case fan.
That said, if you really want to hook up a new fan, go with real quality and get yourself something like a Noctua NF-P12 as your exhaust fan so you are set when you next upgrade.
I see you like your Cool Master gear, but for fans you will get much better performance with someone like Noctua Phanteks or Corsair.
