Shorten the Tubes on Close Loop Water cooling
Hy there...
I am currently building a µITX pc for my Brother and its all kinda finished.
Case i am using: MSI Nightblade
The only thing i cant quite fit in there is the Corsair H75 Closed Loop Watercooling because there is not really any space for the Tubes.
Is there a way to shorten the tubes?
Not really, closed means closed. Even if you did drain it and shorten the tubes there would be no way to refill it
They use proprietary permanently attached fittings. Even if you managed to get it off.. You wouldnt be able to get a perfect seal.. and it will most definitley leak. Honestly at this point you can get the swiftech H series and they are really just custom loops in a AIO form factor and are expandable... thats much more worth it than ruining a good AIO for means of making it fit.
ok .... thanks ... i will have to make it fit somehow else then ... i dont think i can send the cooler back ...
