I’m using the keyboard shortcut a lot to change between computer 1 and 2 (ctrl + ctrl + 1 ~ 4).
However, I’m having a issue where I have to press the windows key before changing back to the initial computer. It appears that the shortcut does not register. So I end up doing the shortcut, not hearing the confirmation beep, pressing the windows key twice, redoing the shortcut sequence and then it works.
Is this behavior expected?
EDIT: I got a 4port KM Switch
