Shimian Monitor Overclocking?
I've heard its possible to overclock the refresh rate on some of the Korean monitors. Is this possible to and if so how would I start. I've looked online for guides and haven't been able to find any.
Thanks
The model number:
Achieva Shimian QH2700-IPSMS Edge Eco 27" 2560x1440 AH-IPS LED DVI PC Monitor
Look up CRU: Custom Resolution Utility. It will be on a monitor forum and will have a full guide with it. If you are going for it it is advisable to go dual link dvi or display port. You can only get so far over HDMI and single link dvi but you will be able to get higher than stock if the monitor will do it with either.
