So I installed Opensuse on my laptop but I have to switch to legacy to boot into it. I found out that Shim allows Opensuse to be installed with secure boot on.
What all do I need to do to enable that feature?
I don't mind reinstalling since I have done much with the current install.
My Laptop is Microsoft Certified, so I can't turn off secure boot.
Secure boot is not an issue at all for OpenSuSE. It will also install the GRUB-EFI variant, instead of GRUB2, so that EFI isn't a problem either, whatever settings you would use.
To make an existing GRUB2 install into a GRUB-EFI install, just change from the one to the other, re-grub-config, re-Dracut your boot parameters, and it should work just fine. If you're not sure, just reinstall and let the installer take care of it.
