Share your tips about inexpensive long-lived low power hardware or other tips!
I this day and age, there are not a lot of good deals, and Nvidia is rumored to increase prices in China again. ECC memory? Poor Jensen and Sam Altman needs it more than you, so you can rent it back from the cloud. Its seems the hedge funds has began a massive sell off of their US tech stocks, and Chinas tech stocks are not doing much better. The US consumers are not buying anything, as many can’t afford it. The tech/AI bubble seems to be the only part of the US eco that has been positive for a long while.
So I thought this could be a way to share tips to hardware incl second-hand that is reasonably inexpensive, does not use a lot of power, and potentially can also have a long life.
I recently got some of Intels SATA SSDs S3520 series second hand. I think there are many other enterprise Intel SSDs.
Another came with the tip, that ppl how has gamer RAM should run it at stock speed and voltage.
Add your own tip or recommendations below.
